Well - before, I had to get something signed which they provided the specefic paper for. This time I didn't get paper for the child restraints to be signed and was told to get child restraints for each back seat and to make sure it's done properly as it is a safety issue - he didn't mention anything about signing or need a certificate. The only Mods I am currently running is a bigger intercooler, Pod filter and exhaust. However, on the paper the exahust is "Ticked" so I'm guessing it passed (but not the noise). I could box in my air filter as they normally do not look under it - they did not note down that I had an aftermarket pod filter so might be lucky. As for the intercooler - that maybe my only issue for mods.
The big pain killer is the suspension but... if I can get a cheap set at a legal high then shouldn't be too hard.
Buy my suspension shocks are awesome height is legal and handles great same suspensiln went though dickson 6months earlier
Man you got fk'd in the bum by RTA
I went in there failed once with my tie rods being modified
Replaced those and I passed
Mind you, my mods were, fuel press reg, eBoost2, FMIC, pod filter, and an atmospheric BOV
CBF replying to everything relevant haha, so:
They made me get them fitted and my report amended. Got the same guy doing the report to do the restraints. Coz he does everything to the book, he had to fabricate the mounts from scratch as the correct location falls inside the speakers (made a "bridge" to go over the speaker but under the mesh). Fabrication of the mounts, testing them to ensure they comply with structural requirements as per ADR, then amending my certificate came to ~$1045 or something. Absolute joke, but not like the kunts at DICKson gave me a choice.
I mean, the pieces of shit were even kind enough to wait until I came back for my reinspection (outside of 30 days from first one) after having done an absolute buttload of f**king around and fixing shit up to get the certificate in the first place, before they failed me for child restraints missing as well as the window tint on my rear windows. Yeah, coz those things were totally roadworthy the first time they went over the vehicle and between inspections I decided to apply illegal tint and remove all traces of the mounts.
f**k Dickson RTA inspection station, and f**k every piece of shit that works there.
Do ANYTHING AND EVERYTHING you can to avoid taking your car there, as well as avoiding getting an engineer's certificate for modifications. If I had my chance again, I would have cancelled the rego and found someone who'll do a dodgy roadworthy. Even if I had to pay them $500 to do it, I'd still be better off having avoided the ridiculous expenses I incurred as well as more stress than I ever want to deal with again.
haha f**king oath I did :(
MY BALLS.
Well:
1 - lololol.....dunno what to do here, since all my indicators work yet it flashes like one is broken sad.gif
2 - erratic headlight beams...just needs adjusting
3 - park lights (front) weren't working, which is odd since it's both of them and they worked last I looked...gay
4 - seatbelt wouldn't clip into buckle. I had the wrong buckle there (registered as 4 seater, discovered lapsash under rear seat. I stashed the buckle before inspection, but I stashed the wrong one lol)
5 - f**k knows what "nut" he means, but yeah...I'll tighten it I suppose?
6 - fuuuuu, getting some braided lines now.
7 - the back rest of my seat has free play in it. I've checked to see why on prior occasion - no idea. Nothing appears loose. Will borrow a seat some a mate or something.
8 - Gasket before cat converter is muffed, easy fix when I put a quiet exhaust on.
9 - apparently there's a restrictor there....which is true, though see next point for lulz
10 - measured 103dB. Like a bawss.
Then the kicker:
11 - I need an engineer's certificate for my suspension/adjustable bits and pieces.
Mods they cared about triggering the need for the certificate were coilovers, rear camber arms, rear traction rods, and HICAS lock bar. When getting the certificate, ALL MODIFICATIONS must be certified - ie, they won't just engineer the ones you ask them for. EVERYTHING was noted on mine, even things that didn't need to be engineered. If it wasn't standard, it was added.
I got my modded jdm evo 8 from interstate and all I had to do was get a rwc from any mechanic and an identity check. Do imports all have to go through dickson now or something?
No. I brought my GTR over from Perth. Inspection at a garage and rego swapped to ACT no probs.
But it was registered in my name already so not sure if that makes a difference.
In july i got defected for blow of valve and exhaust too loud, was told to take the car to Dickson. Made the car as stock as i could but first visit was a fail, was told to fix it and bring it back. Fixed everything that was written down but i couldnt clean the oil under the car as i wanted to hose it down just before taking the car in for my 2nd inspection which was going to make it all nice and clean, unfortunately i sprained my ankle badly while playing soccer the night before the car was booked in. took it in without cleaning them and got the car passed :)
The guy told me everything looks good but there is still lots of oil under the car which needs to be cleaned and i told him i was going to clean it but i sprained my ankle, He just smiled and said make sure you clean it.
My girlfriends wrx was called in for a inspection as someone complained that her car is too loud and they called her in for a full inspection, she just changed the exhaust and we took her car in got it passed.
I think dickson is not that bad for me. its just my person thinking
By the way few years ago i bought my Child safety thing from Trojan motorsport. Go see John, Im sure he can help you out.
Also i only let him touch my car as hes the only one i trust and he can get whatever parts you want for a import.
Edited by 5hiv
  • Like 1
Cheers - Might take it to Trojan and try and get a quote for some of the stuff.
If im not wrong, you used to live in dunlop yea haven't seen you in ages, i only see Rob i guess who drives the R33 4 door.
Yeah that should be easy, the pod and the muffler, but the intercooler? maybe try find a stockie to borrow.
What about just springs, or even sneakier, chock the springs up with something to get it higher.
If you dont plan on having kids in the car, maybe remove all child restraints? could you rego it with none?
child restraints must be in the car, children or not.
pod is fine as long as its securely mounted.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
