You are looking at spending 10k to have it pull hard..
You will spend a lot less if you get your stock turbo highflowed to the right profile, it will definitely give you the pull hard effect and will cost you a lot less.
I reckon a Hypergear G3.5 highflow will do a good job of the desired task, the delivery will give monster pull without being a pig to drive.
Before you ask, you will need a full 3" TBE, FMIC, fuel pump, injectors and an ECU at a minimum.
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069538
It's not rocket surgery.
It's not brain science either.
GTScotT is offering some sound, experience based advice. He's also considering the driving outcome and financial aspect of things.
However if you are chasing a 500rwhp setup you won't likely get there with a GT30 setup. Go the GT35 and be mindful of people's comments to this point.
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069729
At the moment no one has given me a answer or opinion on what one would be more suitable
Yes they have...this:
and see also:
Look at the rb25 dyno results thread. It's not rocket surgery. People don't have to tell you what to do, you can figure it out yourself sometimes!
and forget the GT35
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069772
3076 56T with a .63 on E85 hits like a sledgehammer...
the hypergear stuff in same size are a more linear pull and deceptively quick, but probally faster no doubt
guess it depends what you after, i have no idea what a 3450 feels like on a rb25, only 25/30's and 30s's
guessing boost response would be fairly bad on a manual
cheers
darren
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069900
Glad you put that 3 inch cooler piping, talk about overkill. You can make an easy 300kw on 2.25 inch piping.
Stop slapping parts on and read, there is so much information here you should be able to work out what you need, then see if you can go for a spin in a few members cars to get a feel for the response. I am guessing the GT35 will be a little too laggy if you plan to drive it daily.
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7070093
Read this thread - ultimate RB "pull hard" setup, make numbers in the range of GT35R peak power but spooling similar to the smaller GT30 range turbos:
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7073476
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
    • Oh please, when has anybody really been "done" when they say that? 😂
    • The part where you claim the car "is done" means you won't...
