Cihan (Etuner) is over sunshine way, at Edge Motorworks. He would most probably be able to get a map together for you to drive down if needs be. So would Trent at Checkered tuning, but he is over Dandenong way and most probably booked for weeks. They are both worth having a chat to.
Do you have a wideband going in? Very useful for remote logging/tuning...
Thanks for the information guys its going to a few weeks away at moment
tied up with work for while
won't install injectors & Haltech yet as advised
Was able to get the injector size changed before they dispatch my 0rder from supplier from 555cc to 740cc now
hopefully this will work out ok and get the car running properly
and then i'll have to find a better Diff, I was told 1.5way LSD
thanks again
If the car is going to be driven on the street, then a nice fresh 1.5way lsd is the way to go... a 2 way or a locked diff is just asking for headaches and annoyance.
Do you know exactly which diff is in your car at the moment?
  • 2 months later...
Id agree with taking it to Cihan at Edge, he is very good at what he does, Barry can instal all the parts there before it hits the dyno.
  • 2 months later...
No tuner will fit the SAFC these days, unless he just wants to just take all your money.
Seriously, just buy an Adaptronic. The ECU is a critical piece of the tuning puzzle, it's all that's stopping you from melting pistons. If you can't afford a decent ECU you really need to ask yourself if you should be modifying it at all.
  • Like 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
