Hello everyone, first post on the forum. I live in California and I'm trying to get some info for a project of mine. I have a 1973 Datsun 240z that I'm attempting to install an RB25det NEO engine and 5 speed transmission into. I am having a heck of a time finding a "HowTo" for wiring a NEO engine. I do not want to pay to have a harness build as I'm quite capable, provided I have the info I need to complete the job. I have been scouring the internet looking for any sort of well written how to on the topic. While I was on another forum I saw a member there who had received lots of help from a member of this forum. The member heres name is Simon, but I do not know how to get in contact with him. I'd like to speak with him to see if he would be willing to share some info with me. Below is a link to the other forum post I'm speaking about and in it you will find the reference to Simon. Simon is not the only person I'd be willing to take Info from, ANYONE with the information that is willing to share with me would be greatly appreciated. I am just looking for a basic (These are the wires you will need, ie: color/pin number, to apply switched power, ground, constant power ect) type of help. I appreciate everyones time and hope to have this project on he road soon, given your help.
http://forums.nicoclub.com/my-r34-rb25det-neo-f3-plug-pin-wire-colors-still-confused-t542427.html
Thanks again.
Thank you. I'm digging through the many many pages as we speak, trying to find the info. I'll also try contacting simon-s14 to see if he can help, if he is infact the simon the forum was speaking of.
I looked through that post and it is so long that I cant seem to find the info I'm looking for. But it made for good reading nonetheless. I also sent Simon-s14 a message. I hope to hear from him when he gets a chance. I'm going to go back through that 62 page posting looking for the info I need for my project in the mean time.
If it was my car, for the money its costs (in cal) a proffesionally made custom wiring loom would be the quickest / easiest solution
Might even be one "on the shelf"
To be honest, if I knew of a shop here in Cali that would do it for a reasonable price I'd consider going that route. The car is currently my daily driver so the less down time the better. I don't want to pull the stock engine until I'm confident that the RB is ready to drop in. The sooner the RB is ready the happier I'll be, however paying some shop (No matter how great a job they do, not knocking) $600 for a harness when I could make the same harness myself with a little info, is out of the question. I'm not against doing work the hard way (with wrenches and a soldering iron rather then with my wallet) in fact I prefer it because it gives me a since of accomplishment. But in the end, the car just needs to run and if there is a shop semi local that can do it for a reasonable price I'd happily give them my money. I'm still hopeful that Simon will chime in or I.M. me and spread a little knowledge my direction. I'll keep searching in the mean time, hopefully I'll be able to figure this out sooner rather than later.
Hello again everyone. Sorry for the delay, I have been working late these past couple days and have been unable to work on the wiring lately. So I found the post you listed (Thanks for posting it again anyway) and I have been trying to follow DJRIFT's instructions however I'm having a heck of a time. The first two wires he listed (The white/green and the white/black) were located, however I can not find the 3rd wire he lists to power up. He says to locate a Yellow/red wire just inside the firewall grommet and power it up via a 50amp fuse link. Well the only yellow/red wire I can find is a small gauge wire and when tracing it, it traces back to pin #20, which is (According to the wiring schematic) as the crank signal. In DJRIFT's how-to, he later says to power up pin 20 with switched power. So the wire I wound is obviously NOT the wire he is referring to when he says to power it up via a 50amp fuse link. After this hiccup, I'm worried that I may run into further issues. No offense to mr DJRIFT, perhaps the car he worked on was wired with different colors then my engine. Does anyone have any suggestions? Thanks ahead of time for the help.
Guest
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
