I see a couple of OE turbos now coming out with electronic wastegates, how long before we see these coming out for aftermarket turbos?
I would think these might be an advantage to:
Eliminate boost creep.
Holding them shut during high back pressure (problem with my turbo)
Boost tuning to maximise drivability
Ability to run multiple boost levels
Thoughts?
https://www.sau.com.au/forums/topic/435097-electronic-internal-wastegates/
they have their ups and downs.
have seen some fail.
eg, codes and such, have to replace turbo, not just actuator.
would be good on smaller turbos that arnt pushed extremely hard.
but the units that get alot of heat, I dare say, would affect the plastics and electronics.
They are becoming increasingly commonplace, in internal, external and variable vane/geometry turbos. Later model diesels are even using electronically controlled vacuum operated actuators.
isn't that the same as what most of us with a boost controller run?
Nothing beats a pressure actuated diaphragm and spring, it is a simple and robust design that will outlast any electronic stepper motor or similar.
The only hassle with current actuators is there is usually no way of plumbing boost pressure into the other end, to help the spring hold the wastegate shut. This is why external gates are so much better atm.
actually these electronically controlled acutators...have been used for power valves aka exhaust bypass and most of them fail within 6 mths... electronics and heat dont mix very well... as such i dont expect these to last either. best is still mechanical ones with simple spring and using vacuum IMO.
If they used a huge pushrod to separate the electronics to the valve I don't see why it would fail due to heat etc, anyone got some diagrams and further reading about them?
yes but they would also need to heat shield the electronics as well...then it may be fine
but if its somewhere around the engine bay... wouldnt it still get heat soaked?
There is lots of electronics in the engine bay, all you need is the actuator anyway, then you can put the actual controller in the cabin like a boost controller.
^^ Pre-spooled turbo using a 3 phase RC helicopter motor. I thought of that 5 years ago, even let Tao know. :P
Most of my ideas and designs get made eventually, even if i don't have the time and coin to complete them. Hopefully it flows through to the common people, because I want one.
Actually due to googling IWG's to try and sort my own boost drop issue I ran into quite a few dual port IWG's that do this, but ended up not getting one as I didn't see how it'd help with my (assumed) backpressure problem as the spring inside them all was quite weak.
Would be good for boost control in general though, but I'd imagine most people either don't have backpressure problems or gravitate to just using the tried and true method of EWG's
The spring inside them doesn't have to be strong, as the boost pressure helps hold it shut. I haven't tried one (dual port internal gate actuator) but it should work better than an ewg setup without the top port being used.
wouldnt you need some sort of pitch controll or almost constantly venting valve when it plays generator so your not pumping air into a glosed throttle body? when that opens even a little bit the revs would spike up as you already have constant preasure in the intake, more so than supercharger, seems like that would play some odd games, ok in an f1 car but stop start traffic?
I could see it as control, but if I had say 30 psi on either side of the spring it'd be all well and good.. until back pressure pushes the flap opens and it pulls on the 7psi spring, I could never really find out what would happen then.. I assumed with 30psi on both sides the backpressure would act as though there's a 7psi spring in it.
My laymans thoughts were, if the flap pushed by backpressure can open a 20psi spring with the boost line disconnected (i.e... free boosting with no vac line connected at all I make 17-18psi) I figured this would still occur with a dual port.
Unless I only connected one port, and had 0 psi opening the flap, 30 psi holding it shut, AND spring pressure vs backpressure, but that just didn't seem like a great way to control boost vs just buying a single port actuator head with a 30 psi spring in it.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
