With SONY as their new sponsor?
Dont want to be hating but typical Jo Saward horsesht. Runs a story that has been specifically denied by Sony. He gets about one in a hundred of these things right but it is all (At best) unsubstantiated rubbish.
Having said that sods law dictates that Sony will end up being McLarens new sponsor.
I'd rather watch R/C cars racing than than FormulaE, if that is what they are going to be like, especially with the ridiculous 100m dash that the drivers have to do in the middle of the race when they change cars after 20 minutes.
not as ridiculous as the fans being able to vote extra power to a certain car.
Think it was the weekly Sky F1 Show earlier in the year talked that Sony was a possibility when discussing the bad year they were having and chances of damaging negotiations with replacement sponsor. They were talking how the Honda deal could bring Japanese sponsors on board?!?!? Made no sense to me
And something else I stumbled across. Lotus still have not confirmed a Renault engine deal. Surely they are using one and building the car around it...but dollars from non existant sponsors etc and payments is stopping a formal deal.
I hope they are not in as bad a shape as some media outlets are saying with regards to possibly not fronting as employees still missing pay cheques :(
Im sure they have a renault deal for this year.
Formula 1 driver numbers revealed as FIA announces 2014 entry list.
2014 F1 entry list so far in numerical order:
# Driver Team/Car
1 Sebastian Vettel Red Bull-Renault
3 Daniel Ricciardo Red Bull-Renault
6 Nico Rosberg Mercedes
7 Kimi Raikkonen Ferrari
8 Romain Grosjean Lotus-Renault
11 Sergio Perez Force India-Mercedes
13 Pastor Maldonado Lotus-Renault
14 Fernando Alonso Ferrari
17 Jules Bianchi Marussia-Ferrari
19 Felipe Massa Williams-Mercedes
20 Kevin Magnussen McLaren-Mercedes
21 Esteban Gutierrez Sauber-Ferrari
22 Jenson Button McLaren-Mercedes
25 Jean-Eric Vergne Toro Rosso-Renault
26 Daniil Kvyat Toro Rosso-Renault
27 Nico Hulkenberg Force India-Mercedes
44 Lewis Hamilton Mercedes
77 Valtteri Bottas Williams-Mercedes
99 Adrian Sutil Sauber-Ferrari
http://www.autosport.com/news/report.php/id/112089
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
