Honestly, I wasn't that bugged by 6pm Sunday about the noise. I did get used to it
However it doesnt sound like the pinnicle of motorsport. The V8's etc just sounded so unique and amazing. They really made it sound like 'these are the best engines in racing today'
I won't stop watching or following because of this though. The racing is good just a shame the noise is missing
Seriously the mazda celebrity race had more action and sounded better!
Ferrari, Lotus, Williams need to pull out of f1, Just to show dad (Bernie) who's boss. wakes up Bernie!
Bernie wants them to be loud..... I read an article about how he is doing all he can to bring some noise back into the sport not long after I posted before
The blame is with the FIA from what I can tell
They need to bring back re-fueling, stop banning/changing aero rules and fix the engine problem
yeah from what i remember bernie doesnt have anything to do with the engine changes and was concerned last year that it wouldnt sound good,
and yeah the other day he was saying something if possible something had to be done after a couple of races
http://en.espnf1.com/f1/motorsport/story/149911.html
Edited by MatthewT85
they need more gate
+1
If they sounded like the turbos of the '80's I don't think that anyone would be complaining, I love listening to that era's turbo cars. Instead we have Formula Prius.
I'm sure I heard they don't use a wastegate...
Yeah there is no wastegate :(
Edited by chus13
RBR said they still had a wastegate for safety of the motor, but apparently it's not a necessity because of the energy generation motor attached to the turbine. Doesn't really matter.
Still sound like wet farts.
Get the old cars out the sheds and turn some wheels.
