Honestly, I wasn't that bugged by 6pm Sunday about the noise. I did get used to it
However it doesnt sound like the pinnicle of motorsport. The V8's etc just sounded so unique and amazing. They really made it sound like 'these are the best engines in racing today'
I won't stop watching or following because of this though. The racing is good just a shame the noise is missing
Seriously the mazda celebrity race had more action and sounded better!
Ferrari, Lotus, Williams need to pull out of f1, Just to show dad (Bernie) who's boss. wakes up Bernie!
Bernie wants them to be loud..... I read an article about how he is doing all he can to bring some noise back into the sport not long after I posted before
The blame is with the FIA from what I can tell
They need to bring back re-fueling, stop banning/changing aero rules and fix the engine problem
yeah from what i remember bernie doesnt have anything to do with the engine changes and was concerned last year that it wouldnt sound good,
and yeah the other day he was saying something if possible something had to be done after a couple of races
http://en.espnf1.com/f1/motorsport/story/149911.html
Edited by MatthewT85
they need more gate
+1
If they sounded like the turbos of the '80's I don't think that anyone would be complaining, I love listening to that era's turbo cars. Instead we have Formula Prius.
I'm sure I heard they don't use a wastegate...
Yeah there is no wastegate :(
Edited by chus13
RBR said they still had a wastegate for safety of the motor, but apparently it's not a necessity because of the energy generation motor attached to the turbine. Doesn't really matter.
Still sound like wet farts.
Get the old cars out the sheds and turn some wheels.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
