along that line of topic, I went to a presentation by the engineer (Tony Wallis) who designed the Bishop Rotary Valve for F1 Merc engines...but was subsequently written out of the rules, apparently due to renaults influence on the matter.
interesting design if anyone wants to look into it. Beats poppet valve, pneumatic or otherwise hands down.
A links for those interested.
http://home.people.net.au/~mrbdesign/PDF/AutoTechBRV.pdf
rotary valves are nothing new. IIRC there was a rotary valve head made back in the day for holden grey motors. Dunstan or something. And I doubt that was the first. Rotary valves have always looked good in theory, but have alot of problems in practice.
That was a different design.
There was also a French engineering company that designed a rotary valve f1 engine in the 80's (similar design to the engines you're thinking of) but I think they ran out of money?
The dunstan engine.
post-83669-13986650742943_thumb.jpg.
Aussie designed BTW.
Speaking of cylinder head design, I'm very much looking forward to seeing productionized versions of the 'Free Valve' infinitely variable pneumatic poppet valve actuation system Koenigsegg have been working on with their engine partner. Don't think solenoid valve actuation will ever be a reality with pissy low-voltage car electrics, but this other system has promise.
The dunstan engine.
attachicon.gifImageUploadedBySAU Community1398665073.979800.jpg.
No, that's exactly the same design principle, only difference is in the execution. Dunstan head runs the rotating valve shaft longitudinally with a port that opens to orrifices in the head casting, BRV runs individual rotary valve shafts at 90deg to the crank centerline necessitating a complicated gear drive system and completely incorporates the port into them. Same idea, different execution. The rotating disc valve is a different design, but shares the common trait that they really don't work reliably!
the significant difference is you can see actual images of a real life Dunstan rotary valve head, BRV ironically only had drawings of their design in that article about how they finally made one that worked!
Edited by hrd-hr30
its just a more effective way of a team getting exposure then a normal sponsor....
just like this shithouse 'jandal' crap, was funny when he said it, but getting f**king annoying seeing it plastered everywhere...
And it continues....thjis time STR . Form Autosport
on JEV.... "While there's been some bad luck this year, the fact he has made Q3 three times (and would surely have done so in Bahrain but for a sudden change in the fuel-flow meter readings that forced the team to turn down the engine) shows he has emerged from the biggest disappointment of his career a stronger driver."
Would be simple to throw a bit of redundancy at them by getting them to run two meters
I was at the Sydney Retro Speedfest at Eastern Creek last weekend, and among the classic cars they had there were some old F1 cars, very cool seeing them out on track.
Team Haas Lola THL1
Benetton B186
Williams FW07
Flame Out Surtees TS9B
Edited by 180fan
yawn... torro rosso = red bull
I've read the full decision of the appeals court - "As evidence of the reliability of its fuel flow model, the Appellant provided a series of graphs...Several graphs actually showed that parameters had changed from one lap to the other and that one cannot, therefore, conclude that the fuel flow model did not change notably... On top of this, it appears that not all parameters... were shown in the graphs"
That was their "proof" - doctored graphs and refusing to fully disclose the parameters used to esitmate fuel flow in their model!
Let's put it to rest already.
Edited by hrd-hr30
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
