along that line of topic, I went to a presentation by the engineer (Tony Wallis) who designed the Bishop Rotary Valve for F1 Merc engines...but was subsequently written out of the rules, apparently due to renaults influence on the matter.
interesting design if anyone wants to look into it. Beats poppet valve, pneumatic or otherwise hands down.
A links for those interested.
http://home.people.net.au/~mrbdesign/PDF/AutoTechBRV.pdf
rotary valves are nothing new. IIRC there was a rotary valve head made back in the day for holden grey motors. Dunstan or something. And I doubt that was the first. Rotary valves have always looked good in theory, but have alot of problems in practice.
That was a different design.
There was also a French engineering company that designed a rotary valve f1 engine in the 80's (similar design to the engines you're thinking of) but I think they ran out of money?
The dunstan engine.
post-83669-13986650742943_thumb.jpg.
Aussie designed BTW.
Speaking of cylinder head design, I'm very much looking forward to seeing productionized versions of the 'Free Valve' infinitely variable pneumatic poppet valve actuation system Koenigsegg have been working on with their engine partner. Don't think solenoid valve actuation will ever be a reality with pissy low-voltage car electrics, but this other system has promise.
The dunstan engine.
attachicon.gifImageUploadedBySAU Community1398665073.979800.jpg.
No, that's exactly the same design principle, only difference is in the execution. Dunstan head runs the rotating valve shaft longitudinally with a port that opens to orrifices in the head casting, BRV runs individual rotary valve shafts at 90deg to the crank centerline necessitating a complicated gear drive system and completely incorporates the port into them. Same idea, different execution. The rotating disc valve is a different design, but shares the common trait that they really don't work reliably!
the significant difference is you can see actual images of a real life Dunstan rotary valve head, BRV ironically only had drawings of their design in that article about how they finally made one that worked!
Edited by hrd-hr30
its just a more effective way of a team getting exposure then a normal sponsor....
just like this shithouse 'jandal' crap, was funny when he said it, but getting f**king annoying seeing it plastered everywhere...
And it continues....thjis time STR . Form Autosport
on JEV.... "While there's been some bad luck this year, the fact he has made Q3 three times (and would surely have done so in Bahrain but for a sudden change in the fuel-flow meter readings that forced the team to turn down the engine) shows he has emerged from the biggest disappointment of his career a stronger driver."
Would be simple to throw a bit of redundancy at them by getting them to run two meters
I was at the Sydney Retro Speedfest at Eastern Creek last weekend, and among the classic cars they had there were some old F1 cars, very cool seeing them out on track.
Team Haas Lola THL1
Benetton B186
Williams FW07
Flame Out Surtees TS9B
Edited by 180fan
yawn... torro rosso = red bull
I've read the full decision of the appeals court - "As evidence of the reliability of its fuel flow model, the Appellant provided a series of graphs...Several graphs actually showed that parameters had changed from one lap to the other and that one cannot, therefore, conclude that the fuel flow model did not change notably... On top of this, it appears that not all parameters... were shown in the graphs"
That was their "proof" - doctored graphs and refusing to fully disclose the parameters used to esitmate fuel flow in their model!
Let's put it to rest already.
Edited by hrd-hr30
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
