have just put my engine back into my r33 list of mods below. the problem i'm having it it has nearly no vacuum at idle when it idles at 1500rpm. then for no reason, the rpm will pick up and then idle at 2200rpm.
i have carried out a smoke test on the engine with no results. with the engine running, i have sprayed everywhere around anything that can potentially become a vacuum leak or cause one. e.g (injector seals, plumbing fittings under plenum, around the valve covers, the brake booster, the throttle body seal, the gasket faces) i have blocked of the hose to the brake booster to eliminate the booster, no change there. out of ideas, can anybody help me please. i have spent over $30k on this motor, i need to get it working, really getting frustrated. thanks
engine:
rb25det head full cnc with vg30 over sized valves 1.5mm
custom grind cams from surecams (297 in, 310 ex, 10.2mm lift)
hks adjustable cams gears
plazmaman plenum
plazmaman 75mm billet throttle body
40thou over JE customs pistons
perfect circle rings
brian crower rods
nitrided and heat treated crank
N1 oil pump
davies craig electric water pump and fan controller
hks 1000cc injectors on rb26 hks top feed rail
hks t04z 0.82 a/r rear housing
6boost high mount manifold
hks 50mm gt2 wastegate
plazmaman fmic
GZ motorsport vacuum pump with relief valve
fuel system:
bosch 040 intank
2L surge tank
2 x bosch 044 inline pumps
twin lines to fuel rail
aeromotive fuel reg.
Yeah have checked that also, all spot on. The inlet cam is advanced 3degrees and the exhaust I'd retarded 2.5 degrees. Even with the vacuum pump relief valve done up all the way to hard, it still only pulls -2 inhg, and changing it does nothing. Should see about 5-6 inhg at least without the vacuum is this more or less correct?
This and did you degree them in or did you just bolt them in and think whatever the cam gears say is correct?
Big cam durations=little vacuum natuarally.
Degree wheels set on zero are rarely on true zero, skim the head, change the head gasket thickness and your degree wheels change position slightly, thats why people degree the cams in.
Even at its best, vacuum will be low with such massive duration cams.
Edited by GTRPSI
hi guys, thanks for the replies,
i gave all the specs of the engine to sure cams and the purpose of the car. (80% strip and 20% street). so he went off that bassis. he has done a set of cams like this before, and to his knowledge, there have been no problems. the head has also had solid rb26 tomei lifters installed too.
i have base timing of 15 deg. is it worth trying a little more?
as for dialing in the cams with degree wheel, i will have to ask my engine builder about that. i have used him for years and so have my mates, but some times shit happens i suppose. he also tunes it.
the ecu is haltech e11v2 milspec.
i've been told to expect hp figures around the 750 to 840 atw.
it has a 18psi stall converter and 1300hp powerglide behind it from MV automatics ins SA. used to have built jatco 3 spd from keas, but smashed that to bits with the old setup. that was making around 720hp flywheel
  • Like 1
i would be checking for leaks again. but use an air compressor this time. i was chasing issues and found 2 leaks after pushing over 10psi pressure into the engine. works a treat.
thats a good idea, will try it tomorrow, i'll let you know how it goes either way
ok, smoked tested again and found 2 leaks. had to block the exhaust off to find them though, and still wait about 5 minf for that to fill up. the leaks were at the adjsutment screw on the fuel reg, and at the fitting going into the plenum for the brake booster. now has about 5 inhg at idle, idle around 1800-1900 atm, will do some tuning next week or so. need looser converter though. will post figures pics after tuning.
thanks for all the help guys.
We spoke to Camtech about our 26/30 also with a 80% strip/20% street setup and were recommended 280 duration 11.5mm lift cams for a easy walk in the park 600Kw at all 4 with a precision 7175.
RB30's also tend to absorb lumpy cams a lot better....
Will be interesting to see how user friendly you will find it on the street, post back with how it is to drive after you have tuned it.
Refer to my avatar.
I don't know what angle the tuner/engine builder are coming from with this combination of parts but hope it works out well for you - do the same as everyone else and you get the same results, sometimes its for the better... good luck with the rest of this, update when you've got the bugs ironed out as I am sure a number of us would be very interested to see how this come out :)
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
