We don't have annual RWCs is WA. We only have to take a car for inspection if yellow stickered or registration lapses. As long as your car stays registered, you never have an inspection ...ever...
That's how things like this happen:
post-52031-12726087994694_thumb_zps20295
In all seriousness OP, you were better off buying a stock standard R33 if you were new to turbos. As with any car, you're not just buying a car. You're also buying someone else's pproblem.
I was new to turbos at one stage and guess what? I brought a very close to stock R33 and built it up from there. I was new to V8s too at one stage and guess what? Yep, I brought a stock one and have begun building that up.
People might be saying "but if you buy a modded one, you end up saving money on not having to do those mods" and I agree 100% BUT ONLY if you know what you are doing/looking for. In your case, you were fresh to turbos and you essentially brought a lemon. I can guarantee you 99% of the SAU members on here would not of brought the car you did, based purely on the "mods" that are done to that car.
Knowing what I know about turbos and V8s now, I can confidently buy a heavily modded example and know what to look for and how to maintain it. Unfortunatly, you've thrown yourself in the deep end and your only choice now is to fix the previous owner's problems. Consider it a hard lesson learnt and more than likely you'll end up spending more than the car purcahse price to get it to a level that would be acceptable.
Anyway, back on topic. You'll need to get a pipe made up which will mate up to the ext. wastegate flange and have it welded back downstream into the rest of the exhaust. That will reduce a MASSIVE amount fo noise when you're on boost. If your wastegate is leaking and considering it is vernting directly to the atmosphere (or should I say engine bay), that could also contribute to the extra nosie when you're off boost. Otherwise, get some mufflers thrown in by an exhasut shop if you want it quieten it down.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
