  On 27/01/2014 at 7:26 PM, OS80RN said:
Tell me more about these manualised autos
No electronic control required. You manually select each gear and enjoy the fact you don't need to push the clutch pedal and the best bit is you just keep grabbing gears in a skid
What shifters work? Do you need a new valvebody? What is exactly involved? How does the stall converter react to it? After a manualised auto you can use any stand alone? etc etc... Obviously i don't know anything about autos besides the fact that mine is in good nick. I'm guessing the cost is around the 1-2g mark?
Tried searching quite a lot and i couldn't find anything, and i don't want to waste MV's time by calling them.
A few posts up I have a photo of my b&m shifter under the factory covers. I suggest you give mv a call that way you get all your questions answered they are good guys to talk to
  • 4 weeks later...
Are these the options or tuning the auto skyline r33 :
Toshi's tune
Nistune..need more info about this
eManage blue/ultimate
Safc and sitc
Power Fc
Are these users able to retain the shift logic? Toshi is all out of auto ecu's and wont be importing anymore so I dont know if he is an option. He mentioned not being able to do over 200rwkw or so on the eManage.
Want to see in excess of 230rwkw (have usual mods - intake/exhaust , injectors , fuel pump - high flow turbo to 18psi , trans cooler , mv valve body upgrade)
What ecu can I use that will retain daily drivability but get me to 230rwkw?
Nistune, Nistune, Nistune, Nistune, Nistune, Nistune, Nistune with a side of Nistune.
Just Nistune.
Nistune is what you want.
Nistune is what everyone should want.
I also realised after I wrote Nistune a lot, that the person asking has a 33 Auto, to which I have NFI if Nistuning will work as they typically change the ECU to a Z32 or RB20 ECU to boot.
Unsure if that even applies to Autos, actually.
  On 28/02/2014 at 5:38 AM, Anfanee said:
Oh i came here thinking that if i ask a question it would be automatically answered. Guess i came to the wrong neighbourhood.
Took me a while to get that. It was that good -_-
Edited by superben
Soo funny I forgot to laugh ;)
Stu cornall tuning services in qld is making them. Just sent him a msg on Facebook.
If he doesn't reply, does someone else want to call him? I've been watching him from afar and following him from work and home. I KNOW he has been ignoring me!
Edited by Stagea97
lol stalker much :)
Just Nistune.
FYI This is what the director of Nistune had to say after I emailed him regarding using nistune on an r33 automatic:
The only option I鈥檝e found so far is to use the R32 ECU, TCU and an aftermarket VCT controller. This has been done by Steve at Advanced Jap Auto in Vic with indicated the setup works since the r33 TCU cannot be used with R32/Z32 ECUs
You would also need to upgrade the MAF to Z32 over 220rwkw
We cannot nistune the r33 ECU at this point. Another person is working on a solution but no news since Dec
If you wished to do this way then you need to source the R32 ecu and tcu plus Summit racing, buddy club etc RPM trigger switch for VCT and Nistune Type 2 board loaded with rb25 maps
  On 13/03/2014 at 1:38 AM, Stagea97 said:
Any word on the nistune?
I want better fuel Econ, so piggy backs are a waste of money.
None yet. The guy who is building these for auto 33's has my email so will let you guys know as soon as he gets back to me.
  On 13/03/2014 at 1:51 AM, GTSBoy said:
Why not look at the Nistune forum? The thread is easily found.
Can you link me?
There's been no word since last year, the multiple threads on the net don't tell me anything on where it is up to.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 馃槢 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
