Hey guys,
I've searched and i can't seem to find what i'm after, so i thought i'd ask.
I was looking at buying a RB26DETT to put into my R34 GTT, But after looking around and talking with people. I've been swayed into looking at 26/30 builds. Only downside to this is i have no idea about them, the benefits or what is needed to build one/cost of it all?
If someone could explain the benefits of doing this and rough list of parts/costing. Not chasing huge power at the moment but down the track that will be the goal.
Cheers in advice
https://www.sau.com.au/forums/topic/437616-rb2630-help/
Use the NEO head.
NVCS Yo!
Really? From what i've been reading most people go against using the NEO head? All in favor of the 26 :O!
and way better comp comp ratio with stock pistons.
op, you have a lot of reading to figure out what you want.
I know there is alot of research left to do, but i can't seem to find any kind of basic guide/build threads out there i can see that would help me to a point. I'd say i'm aiming for around the 300-350 rwkw mark, being that the egine won't be in the car for awhile i'll have change to change mind and forge internals if i want to go down that path. Just need a push in the right direction to get the ball rolling
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170735
Have you tried the search function or Google?
Here is the guide (in the very first pinned thread in the RB30 section):http://stevenwelsh.site.net.au/RB30_DOHC.pdf
and the third pinned thread in the RB30 guide is the RB30/26 guide.
Then at the top of the forced induction section you can see results including what was done for RB30/25 and RB30/26
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170769
Why dont you work your original engine for your power goal?
Keeps the car legal, im sure your local police may not be too happy finding out its a RB30 with a 26 head in a GTT.
For the power your chasing its not worth the effort, use what you already have.
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170772
I did try the search function, As i said. But thank you for being a smartarse and linking me the page and telling me other places to look.
Its Tasmania, We don't have defect stations ever ;) I figure i will want more power down the track its just a starting point, unless you can push the same amount of big power out of a 25neo as a 30/26
  • Like 1
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170805
It doesn't cost a huge amount more to build a 30 as opposed to anything else, it's mainly sourcing the new stuff that's different and the machining that adds up. You end up adding a whole heap of extra stuff as you go.
My engine (which is still not finished) would have cost me $15000 I'd reckon. A lot of that has been upgrades that you would do on any performance build though- new dumps, new clutch, all new genuine hoses, new timing belt tensioners, etc, etc. The list is never ending!
No disrespect intended but I would learn a bit more about your car first before committing to a 30 build. Spend money on upgrades that can be transferred over to the 30 once you build it (turbo, injectors, fuel pump etc). Once you're used to that power then go the next step. Totally my opinion but it's your money!
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7171224
^ agreed 100%. You always end up spending money here/there.
IMO as others have said, stick with the 2.5ltr for now... Make your 300-350rwkw on it. Put decent suspension, brakes and so on into it and learn how to drive it.
While in the process of learning how to drive it with 300-350rwkw, build that 3ltr bottom end while you wait for it to pop (which will likely come eventually). All the engine ancillary parts will transfer with regard to injectors/ECU and so on if you think and plan ahead.
The ONLY thing would be to buy say a GT3076 for now so that it is not too laggy, once you have a 3ltr then put a larger turbo on there. You're only talking ~$1000 extra expenditure but if you get 1-2 years outta the 2.5ltr and so on, then you've had 1-2 years of a really bloody decent set-up with great all round performance and good power as opposed to putting a big turbo on first and it being laggy and you end up hating it.
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7172265
and everything is stock i built it stock rb30 200+ks engine and if u use a rb25 s2 head rips make a oil line for it on ebay like 80$
AND it cost 1000 $ to build rb25det oil pump, bearing set ,pistons and rings rb30et and head gasket and arp head bolts
Edited by r32_rb30det
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173325
in my 12 years experience, my opinion now days is f**k it.. get a good stock motor and put quality supporting mods on it and quality tuning with e85 and make good strong reliable power.
ive built motor and blown them up, due to the silly little things that can go wrong, so financially im better off running an OEM motor with mods.
my car is proof of that, stock RB30 with 26 head, all supporting mods. 412 rwkw on 22 psi and it gets thrashed...HARD
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173332
The only downside to E85 tune would be the lack of places that sell it close by to me. As far as i'm aware the closest place to me is 2-3hours away. So for now anything i do will be 98 pump tune. So you also think i should stick with the 25det neo and just support mods on that? The engine sits standard at the moment with just shy of 160XXX Kms on it.
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173867
Yep get a Nistune or Link, bigger turbo, injectors, afm if necessary, fmic, fuel pump, exhaust and a good tune. If you want an RB30 later you can transfer the head and all the other bits.
  • Like 1
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173907
thats the way some as me stock as a rock rb30 limiter bashing hard
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7175114
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
