Forgive the terminology, maybe I will get it later on
Well bs is still alive in the carsales industry and why am I supprised :verymad:
The R34 I am buying that was supposed to be able to be tuned to 700HP to 800HP could not make 400HP. It could not get enough boost to kick the turbo off.I think he said it was only about 12 lb., it was about 200KW :(
Had it on the Dyno today and found out I need a turbo boost controller and new cam once the turbo controller was installed to be able to take the power it was capible of acheiving , Mmmmmmm :verymad::yucky:
Trouble is learning can be an expensive business :pirate: Grrrrrrrrrr!
https://www.sau.com.au/forums/topic/438031-honest-car-salesman/
What makes you think you can achieve 700+ HP? What Turbo are you running? Is that your engine bay in your avatar? looks like you have a high mount single?
Going from 200KW to 350+ with just a change of boost controller is highly doubtful... Unless you can tell everyone what the specs are of your engine...
Thanks for your input guys, I have paid the deposit and signed the contract, I am not worried about that, the car is worth it to me, I just get sick of being crapped to.
The motor work was done by Croydon Racing Developements and from what I found out about them they know what they are doing.
The car had $42K SPENT ON THE MOTOR , too many things to write and most of it I do not understand but here are some of the mods; GikenT78 Single turbo kit, OS quad Clutch, push /pull kit, Koyorad radiator , custom made catch tank, Z32 air flow meter', ,nitto h beam connecting rods; je/nitto rb 26 forged pistons, nitto rb series high volume oil pump, 9 lt sump conversion, machine work on engine block, engine rebuild- hand file rings ect, bosch fuel pump ; and all of the other bits and peices that needed to be done.
That is not counting stuff that Advan Performance did, I think they know their stuff.
So there was alot of money spent and the work was done by people in the performance business. I feel OK about the car, well I love it :thumbsup:
I do not know very much about getting a R34 up and running and I maybe wrong, but 600HP, I will soon find out?
Some of the parts should give someone an idea of the type of work done on the engine, no thoughts on what was done to the engine can get up to 600hp ?
When the cam and boost control have been fitted and after the final tune mid next I will take a photo of the Dyno readout and post it
A bit late it seems.....
They just added the Boost controller and Dyno done, 338 AWKW ,so nowhere near the sales pitch talk.
Spoke to the bloke at CRD and he said it is a good unit and if I wanted more from it i would need to update the fuel system and a new cam and they could lift the performance, think that will be enough for me for a while and see what I want to do in the future .
So I will pick it up on Saturday and see how it goes on the 330 kls ride home , should be fun :action-smiley-069:
Normally when those figures are thrown around it means that the engine is capable of making that power given all the supporting mods are in place.
You clearly didn't do much research into what you bought, u just saw a big parts list n they told you this n that and you were none the wiser.
Without a complete fuel system including surge tank and external pumps it's never realy gona make over 400kw (540 hp).
Mine maxed out at 401kw
Also a fuel system from croydon is not cheap, I know from experience as they built mine.
So unless your going to spend cash on a fuel system and upgrade to e85 your not going to see over 550hp
Also who builds a forged motor with all that and doesn't even put in a simple boost controller?
Also a Gtr has camshafts (there is 2 of them)
If it didn't have a set of basic aftermarket cams in there all ready then I'd take it that no head work was carried out at all and now even less likely to make 7-800hp
also 800 at the wheel/ dyno hp is a f**king monster. do you want that sort of power, do you understand what that is like to drive and maintain?
if you get a solid reliable 450-500 atw then you have got to be happy.
sorry to say it again but if your not sure on whats what with the parts list then a 7-800hp car might not be the best idea to chase.
do you like driving it? is it a good car? then drive it love it and be happy with a good purchase.
i can say my rb25 is capable of 800hp.......with $200k
Edited by GH05T
Ontop of that it would be boring as hell to drive everyday as with that power you are not seeing boost in the rpm you spend most your time in on the road, when I drove a 500kw gtr on the road it really felt boring compared to a 350kw one that is until you go past 5-6k lol.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
