Very nice indeed Tim. :yes:
I should have thought of the obvious! > pre-nap under a tree - palm tree no less.
That reminds me of the time that Sherlock Holmes and Dr Watson were lying on the ground, gazing at the stars...
Sherlock: "Dr Watson, what a sight that is!"
Dr Watson: "Yes indeed Mr Holmes!"
Sherlock: "But can you see what is wrong up there?"
Dr Holmes: "Other than the occasional meteorite, there seems to be nothing unusual."
Sherlock: "But what about the fact that someone's nicked our tent!!!"
My tool box was obtained from a hock shop > probably a bit more scratched up than yours, but functional art, all the same!
Gave light painting a try and then started mucking around in photoshop, to try and hide my bench top. (got a bit carried away)
I going to get a better torch and some white cardboard, to use as a reflector, to try out lighting the object next. As I'm still very much a beginner
Your all a bunch of tools!
Last week I did my first real model shoot. The model is wearing a body paint Harley vest to suit the bike. Feel free to chip in with any CC on the following shots.
My CC on these shots: next time you're so close to my house for one of these sessions, I will not let the heat stop me from coming along to help...
Seriously though, in the top photo there's just a little bit of light missing from the right side of her face that doesn't quite work for me. Maybe I should have been there to hold a reflector to bounce some light. :P
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
