Perhaps it is just that Im a ham fisted monkey, but, I have been having trouble with the 3/4 cluster in my R33 gtst box. I find that the 3 tin clips that hold the selector dog fold the ends off if they get rushed. Then soon after they fall out and the dog doesnt mesh onto the syncro or gear making the shift clunky/grindy as all get out. Most other boxes have a solid blocker system, like the setup in the 1-2 cluster and is much more robust.
Initially the tripple plate clutch was swapped out for a good single to reduce drag on the input shaft, which helped, but now that I'm giving the GT3's a hurry up at Morgan Park, I am pushing through the gears and tending to stress these clips and having to replace them every meeting.
How do you guys fair with the clips?
What did the old group A 32's do? They have the same gear set, we have actually have a 32 gtr gear set in at the moment. It was a cheeper option for a spare set on rotation.
https://www.sau.com.au/forums/topic/440189-gearbox-mods-for-racing/
We have added an extra guide to the 3/4 selector fork, the thought is that the selector dog isn't supported propperly and can fall over. The extra guide might help maintain it in an upright position and take some of the load off the 3 clips. We will get this set back toghther and test it out at Lakeside this weekend.
Edited by Noddy
That's a good idea, interested in how this develops - the SR20 box has the same issue too. I'll have a look when I'm in the workshop tomorrow but perhaps there's a way of going to some sort of spring and key in the hub, rather than the clip arrangement (I can't quite picture the setup at the moment)? I know it would be a bit of machining but may be worth it if it's a recurring issue.
There is a few people Ive spoken to in the last few days who have done similar things with good results. Tig welding extra material in at the top, machining it back to make a slipper pad has been a suggestion too.
I spoke to a guy who worked on the groupA 32's, They used hollinger inturnals. We spoke to Hollinger not long ago about getting some gearsets made up for the Nc RX2's we run (Hollinger used to make them a few years back) but, they were not interested... unless we were going to order 1000 sets. I fear that the gtr stuff will be in the same basket.
lol, and nissan are out of the stupid clips and 3/4 syncros....
because you've personally killed them all!
sorry I am no gearbox expert but with the GTR box I do know there were changes for the last series (series 3 r33), and that the old design was made obsolete. Since the internals are similar/the same are there any series 3 changes you can apply to your box?
BTW great to hear the old girl is still hustling around tracks nicely :)
yep, She has had 2 years sitting in the corner. I picked up a levin on my last trip to Japan and, it has distracted me for a little while. There is a new motor in the pipeline, a pretty silly 26/30. It's all together on the engine stand ready to go in the front cut that came off the black 33 (from the aust titles) for a fit out for a custom dry sump, mounts, piping etc. Then Ill just swap it into the yellow 1. You have to race at Lakeside some day. It'll blow your socks off Duncan.
The changes made worked well at lakeside: however, I was in 4th and 5th for most of the lap there so whasn't much of a work load for the hub. The only time I had an issue was on a down shift when I messed the double clutch up with out enough revs.
  • 3 weeks later...
Have a look at upgrading to an R34 3/4 synchro/sliding hub setup, they use solid type key.
D22 navara's also use some of the same gear just under different numbers, but it is hit and miss with the models
  • 3 weeks later...
General question for those doing track days in R32/R33 GTR's... what gearboxes are you running and power are you racing with?
I am looking at some options at the moment; the OS Gearset seems to be the most cost effective with the 1-5 kit, billet shaft and billet plate totalling just over $3.3k... but I am not sure how many people are racing with them?
Anything after that like a PPG well you can multiply by x3 just to get a gearset without a billet shaft.
I am starting to think just be gentle with the stock one and put the pennies away.
  • 8 months later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
