Perhaps it is just that Im a ham fisted monkey, but, I have been having trouble with the 3/4 cluster in my R33 gtst box. I find that the 3 tin clips that hold the selector dog fold the ends off if they get rushed. Then soon after they fall out and the dog doesnt mesh onto the syncro or gear making the shift clunky/grindy as all get out. Most other boxes have a solid blocker system, like the setup in the 1-2 cluster and is much more robust.
Initially the tripple plate clutch was swapped out for a good single to reduce drag on the input shaft, which helped, but now that I'm giving the GT3's a hurry up at Morgan Park, I am pushing through the gears and tending to stress these clips and having to replace them every meeting.
How do you guys fair with the clips?
What did the old group A 32's do? They have the same gear set, we have actually have a 32 gtr gear set in at the moment. It was a cheeper option for a spare set on rotation.
https://www.sau.com.au/forums/topic/440189-gearbox-mods-for-racing/
We have added an extra guide to the 3/4 selector fork, the thought is that the selector dog isn't supported propperly and can fall over. The extra guide might help maintain it in an upright position and take some of the load off the 3 clips. We will get this set back toghther and test it out at Lakeside this weekend.
Edited by Noddy
That's a good idea, interested in how this develops - the SR20 box has the same issue too. I'll have a look when I'm in the workshop tomorrow but perhaps there's a way of going to some sort of spring and key in the hub, rather than the clip arrangement (I can't quite picture the setup at the moment)? I know it would be a bit of machining but may be worth it if it's a recurring issue.
There is a few people Ive spoken to in the last few days who have done similar things with good results. Tig welding extra material in at the top, machining it back to make a slipper pad has been a suggestion too.
I spoke to a guy who worked on the groupA 32's, They used hollinger inturnals. We spoke to Hollinger not long ago about getting some gearsets made up for the Nc RX2's we run (Hollinger used to make them a few years back) but, they were not interested... unless we were going to order 1000 sets. I fear that the gtr stuff will be in the same basket.
lol, and nissan are out of the stupid clips and 3/4 syncros....
because you've personally killed them all!
sorry I am no gearbox expert but with the GTR box I do know there were changes for the last series (series 3 r33), and that the old design was made obsolete. Since the internals are similar/the same are there any series 3 changes you can apply to your box?
BTW great to hear the old girl is still hustling around tracks nicely :)
yep, She has had 2 years sitting in the corner. I picked up a levin on my last trip to Japan and, it has distracted me for a little while. There is a new motor in the pipeline, a pretty silly 26/30. It's all together on the engine stand ready to go in the front cut that came off the black 33 (from the aust titles) for a fit out for a custom dry sump, mounts, piping etc. Then Ill just swap it into the yellow 1. You have to race at Lakeside some day. It'll blow your socks off Duncan.
The changes made worked well at lakeside: however, I was in 4th and 5th for most of the lap there so whasn't much of a work load for the hub. The only time I had an issue was on a down shift when I messed the double clutch up with out enough revs.
  • 3 weeks later...
Have a look at upgrading to an R34 3/4 synchro/sliding hub setup, they use solid type key.
D22 navara's also use some of the same gear just under different numbers, but it is hit and miss with the models
  • 3 weeks later...
General question for those doing track days in R32/R33 GTR's... what gearboxes are you running and power are you racing with?
I am looking at some options at the moment; the OS Gearset seems to be the most cost effective with the 1-5 kit, billet shaft and billet plate totalling just over $3.3k... but I am not sure how many people are racing with them?
Anything after that like a PPG well you can multiply by x3 just to get a gearset without a billet shaft.
I am starting to think just be gentle with the stock one and put the pennies away.
  • 8 months later...
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
