I didn't use a relay. I just connected the power/ground from the Mojo harness to the stock power/ground plug and everything works as advertised.
Scott,
I thought I read in a couple of places that the stock dwell was 1700ms. If 2500ms that could be why mine are working without breaking up even with a rich 10.5:1 WOT A/F mix.
while ive never measured the output of the stock ecu, i for some reason assumed it to be around the 2500 mark as im pretty sure thats near full saturation of the stock coil pack, and most ecus have the rb base map set to that, according to the nistune users guide most stock nissan crap is around the 3ms mark, id need to scope the output to be sure though, so you may very well be right, yet one thing i noticed straight away was leaving the dwell the same and putting in the ls1 coils made a huge difference when running stupidly rich mixtures
XKLABA,
I'm running 2.2 bar boost and not using a relay and like I said pretty rich A/F mixtures at WOT. And these coils work WAY better than my Splitfires using the same power source and dwell.
Although, I did replace my engine harness about 5 years ago so my power/ground wiring might be in better condition than other cars with 20+ year old wiring.
I did a mod to mine with a relay and power sources directly from the alternator, then use the factory line to trigger relay with the relay feeding the positive power supply directly to coils
Made a very little difference to idle and it revs a little more freely
I keep LQ9 coils @ 3ms max @ 14v and 2.8ms @ any higher as they're a relatively fast charge coil (compared to yukon / D585 and LS1).
Any more and a small spike in alternator output voltage can advance timing intermittently.
Before using any GM coil without a 3D lookup table for coil charge time - log alternator output to certify it is operating within OE parameters hot and cold and up to redline - especially if combining with aftermarket alternators (ie. high output units that aren't underdriven).
Installed mine this weekend while on my mini vacation.
I used the Mojo harness and plate. My coils/ignitor/harness seems to have been going bad because the car hasn't felt this good since I got it tuned a few years ago. Had to redo the timing after install, when I put the light on it showed 10deg. I was also getting spark blow out @ 18psi and that's all gone now. Happy camper over here.
looks good :)
are these genuine ls2 truck coils or the china spec AC Delco D585 with the BSC1251 part number ?
looks good :)
  • 1 month later...
I'm weighing up this mod vs a set of yellow jackets for a sub 15psi setup. So far in terms of cost it would be slightly less but still similar to a set of yellow jackets. Would be nice to run a 1.1 mm plug gap
This is looking at a set of ACDelco D585 coils with the BSC1251 part number, plus a full set of suitable connectors and wire etc.
Are the BSC1251 items to be avoided if you're not chasing high boost, or would it be no better than chucking yellow jackets in and calling it a day?
Lastly, I would want to make a coil on plug setup which still fits in the valley. I notice in this thread that the pictures are of engines with forward facing plenums, therefore they do not have to consider clearance between the coil setup and the crossover pipe. Will the d585 coils still fit?
I use the Mojo plate and can bolt the valley cover down over the coils (rb26) so I'm sure your crossover pipe will still fit.
Cool, that just leaves the question of the BSC1251 AC Delco coils being worth the effort to install over a set of yellow jackets. Even if theyre the chinese version, I believe they are still regarded as an OEM replacement by AC Delco?
they are not set to the same quality control, but they might be designed close to spec.
  • 4 weeks later...
Be very careful with your dwell and the D585 coils, we have been able to replicate in testing the "early" fire conditions many tuners have been experiencing.. with D585.
By "early fire" i mean uncontrolled ignition advance.... which can lead to major engine damage.
Keep your dwell tables safe and if possible use voltage and rpm modifiers.
http://forum.nistune.com/viewtopic.php?f=12&t=2423&sid=c7498fc38b9a5b973935a6a6cadb99b8&start=45#p22083
http://forum.nistune.com/viewtopic.php?f=12&t=2423&start=30#p20865
  • 5 weeks later...
Maybe someone on this thread can tell me if my problem is coil related, build only just completed
Goes well to 5000rpm ,slow or hard in any gear
In neutral at a steady 5500rpm it sounds like a quick, blop blop blop sound, you can just hear it
In 2nd go hard and between 6000 to 7000rpm it coughs and splatters , keep pushing it back fires a bit, blows a bit of soot
In 2nd slowly build the revs to 6000 to 7000rpm and it dies, feels like the fuel has been cut off but after that ill will kick on again
The new plugs were changed twice, they looked a little dirty, but ?
Have Splitfire coils, they were put in the car 6 years ago but were not used for the first 5 years, only about 4000klm on them. The Mojo packs sound interesting
Sounds like tune to me, they are renowned for tuning to rich and to rich will drown spark
You need to get it to someone that know what the fark their doing so they can diagnose it properly
Even if they can just run it up and tell you whats going on
But giving a car back like this is massively piss poor
Every work I have done with them has seemed rich and blows soot all over everything..
After my last work on the old motor, the car was driving very well, could get going at 6000rpm with no lag, after a few weeks it lost this ability and got more sluggish, but would still drive to the limiter @ 9500rpm
This new problem seems a bit worse than the plugs getting dirty, drove the car home 350klm , 2 days later I did a 5k launch and it seemed OK, the next day tried at 6500rpm and the problem surfaced.
They have the ECU locked, there is a mob in Port Macquarie I might try before I make my mind up to take it back.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
