Hey there, just joined the forum and also just got me a 91 r32 GTR, I'm kinda familiar with the car, didn't see or talk of many growing up.
But I'll just get strait to the point, I've got this great car and i want to throw some money in it. So far its stock I've got a basic understanding of modding a car but i figured because there's so many people doing it on here maybe you could point me in the right direction. Any help is appreciated thanks.
https://www.sau.com.au/forums/topic/440558-rb26-basics/
Consider yourself pointed in the direction of the rb26 dyno results thread stickied in this forum.
Or by pointed in the right direction do you mean have exactly what to do to your car spelled out to you based on not specifying a budget or goal?
Sorry if that comes across harsh,but seriously all the info is on this site,and your question can't be answered as theres not enough info.
Edited by superben
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7228988
No worries dude.
There is obviously heaps of advice to be heard, but without having a goal and budget in mind it's all a waste of time
I would start with a full change of all fluids,plugs, timing belt,tensioner,cam seals, etc to make sure you are starting with a solid base.
One you start modifying it you are opening up a bigger money pit!
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7228990
Something tells me this is either a troll or someone who bought a car before doing any research AT ALL!!!!
You have a stock R32 GTR that you are wanting to smack 2JZ's with and run a 9.66....... do yourself a favour and sell it as i can see the next thread being 'i got done street racing' or 'my engine blew up, what do i do now?'
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7229055
lol, i just re read it and read it properly, sorry dude :(
As has already been said, the first thing i always told people to do was a fluid change, water pump and all timing belt bits (belt, bearings, bolt etc.
Good oil is always going to help and i have ALWAYS used Motul 300V 20W60. Have used it in so many cars with minimal wear on even race engines.
A decent catch can will help prevent any blow by going back into the intake which helps in many ways
Last but not least pray to the car gods that the oil pump doesnt fail
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7229160
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
