Mick how does your system go for noise suppression?
It would have plenty of flow capacity, be good to see pics for how it looks and fits.
It's a lot quieter then the 80mm jap exhaust I took off, it's not that loud until you get on the loud pedal then it gets up there, but idleing it has a nice tough murmur, Paul heard it tonight maybe he can comment on it
I have GT-RSs on the car so I needed as much flow as I could fit under the car
How about this , where your oxygen probe goes get a plug and drill/tap/braze whatever a take off into it and measure the pressure in the exhaust behind the turbocharger .
Compare it to boost pressure and note the difference .
It may not be a bad idea to pull the cat out and see if its blocked or collapsed as well . Changing that mid muffler shouldn't be a biggie surely .
A .
Couldn't hear it. All I heard what that farken pump. BBBBBZZZZZZZZZZZZZZZBBBZZZBBZBZZZZZBZBBZBZZZZZX
  • Like 1
That's not really the ratio you're supposed to look at against boost pressure though. Ex manifold pressure against boost - yeah, fine. But not really dump pressure. Realistically, if you have more than a couple of psi of back pressure in the exhaust you're looking at a substantial restriction. So measuring the pressure there is a fine idea, but you're really just looking for the absolute amount of backpressure.
It would also pay to measure after the cat too, just to see if the cat is the problem or if the mid muffler is the problem.
But, my 2c on that issue is (which coincides with a lot of opinions above)
1) Why not just drop the exhaust behind the dump and take it for a quick drive, see if it changes behaviour?
2) Unless there is a massive step down in the muffler(s) it should still handle quite a bit of gas flow without killing the power. So you have to wonder about tthe cat more than any other part.
Well this thread is about exhaust restriction and anything significantly positive behind the turbocharger under load tells a story . I just picked on the sensor location because it's an easy place to tap from . If that exhaust is restrictive and gets fixed the dump pressure should fall and so should the exhaust manifold pressure . Boost and power characteristics should change as well .
A .
What do you guys think of this - ok or a pile of junk? The cat is a gutted catco item (what I was suggested with a bit of reluctance), the mid-muffler looks 3" in/out (no necking like mine), the rear muffler is a crappy jasma cannon but free-flow from the look of things.
System is off a 33GTST goin for cheap ( I know 34 is slightly shorter) and the I'm thinkin of buying it..
Edited by rondofj
Doesn't seem too bad for $100
Has a gutted cat already and a 3inch in and out same side mid muffler so that shouldn't be a problem
Just sack that rear cannon as most jasma approved mufflers have a smaller inner pipe which the oval muffler should fix
Worth it for $100 imagine how much it will be for a new custom 3inch catback atleast $500
The step down pipe is rarely in the mid muffler
Is almost always in the rear muffler or cannon
If the mid muffler is stepped down it's usually on the inlet or outlet and not internal as that muffler isn't offset so will be straight pipe thru just perforated and packing around it
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
