WEEKEND UPDATE!
scotty had to remove and weld up my throttle body/afm, where the iacv valve should be. i will get him to barb it in the future so i can remote mount it.
all this was required to fit the euro spec top feed micra fuel rail. (its from the same engine, just a 10 year on updated coilpack version)
we then added various o-rings and shiz (scotty is a genius at this, i wouldnt have known where to start)
370cc neo/stagea injectors installed!
i then spent freaking ages trying to get a 33gtr pump installed in the stock cradle. eventualled managed to get it in there with a slight change in where it picks up from......
tank was drained of dino fuel and replaced with 20 litres of e85.......
i then pulled out my shiny new nistune fitted ecu. installed it, and primed the pump a few times. we found a small leak at the fpr, and just found it wasnt seated properly. scottty bent some welding wire and inserted it, holding the fpr down and leak be gone!
guess what.
it works.
took it for a couple of laps around the estate and it works fine, even getting some boost down very very low, so i have to be careful.
she is ready to be tuned!
apart from one small tiny thing.
the pick up location of the fuel pump no means if i go round a right hand corner with less than half a tank, it stutters hahah!
we filled her up with e85 and i went for another spin. shes fine. will drain the tank at a later date and rotate the pickup.
nistune, added 30% more fuel across the range to allow me to use e85 to get there. the car is running hella rich, but drives fantastic.
really looking forward to friday';s results.
next on the agenda is to finish the swift gti seats install. they are slightly higher up than the micra seats, but this is fine for now. will head over to finish welding the passenger on thursday and pick the car up for the tune.
f**k. yea.
literally the stock ecu with a daughter board attached to allow tuning of factory maps.
sure it doenst have duel maps, and the features of all the other options, but its the cheapest, and thats what matters! haha!
what do you run on the pulsar?!
yeah thats what I thought. good jerb
was just curious as pulsar version of nistune is just a daughterboard. its cheap, easy and effective for what you need for +T. however apparently skyline version is $$$.
(I have powerfc but know heaps of turbo and VVL pulsars on nistune)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
