Today my 1999 S2 Stagea (RS4S) hit 100,000 kms, and it was kind of upsetting. It made me feel like the car had graduated to the next age of car life.
But then I realised, this is a ~15 year old car, it must be going pretty well to only be hitting 100,000 now. Right?
So tell me, how many Kms has your Stagea done?
100k club?
200k club??
or a special garage dwelling <50k?
https://www.sau.com.au/forums/topic/443149-how-many-kms-has-your-stagea-done/
100k club?
200k club??
Just get speedo wound back as per most jap cars....
Edited by Ben C34
78,000km ('04 PNM35), and from the condition I'd say they're genuine. Still had some factory plastic protective film in places when I got it, I don't think anyone ever sat in the back.
96 model, 130k kms. Can't be sure if it's genuine. Some doubts for me are that Ive replaced the turbo. It wasn't blown but had too much shaft play. Front shocks were totally worn by 100k kms on the odo, which Im not sure if its normal since it's a heavy car with sporty shocks. Maybe too much wear on the drivers seat too. No point dwelling on it. Its running well and is in good condition now.
Just over 300,000.Killeran, I'd suggest getting Japanese History Check to prove your KLM, I think its very unlikely a car has done under 7,000klm per year every year of it's life...
I think many of the answers here would be ???,???kms.
It's been endemic in the industry for a long time.
  • Like 2
98 rs4, bit over 228000kms, pretty good condition, it's had a turbo at some point before I bought it, only engine repairs I've done are timing belt and all front seals and water pump. Heaps of stone chips and some rust under the mirrors.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
