I was wondering if anyone has used a stock Series 2 ecu in a series 1 R34GTT.
I have a series 1 R34GTT manual and want to install a series 2 ECU.
I know there was a torque increase in Series 2's and a few other changes, so I am wondering if the ECU was different as a result.
Thanks
https://www.sau.com.au/forums/topic/443530-r34-gtt-series-1-v-series-2-ecu/
I have a Nistuned GTT ecu that's already been tuned for Air filter/interfcooler/exhaust and 12psi for sale for $400
For example you're better off buying something like that and then getting your afr checked on a dyno or even a touch up tune.
I really can't see any benefit in trying to chase a particular series ecu for little to no gains when you can have the car setup perfectly for its current time real world condition.
Reason i ask is because i currently have an impul ecu which is tuned for jap fuel i think. I bought a series 2 ecu to put in my car to avoid any issues driving using 98ron. I have however bought a series 2 ecu and wanted to check that it will work ok in a series 1 before i install it. Definitely didnt get it for the power increase in series 2. Just wanted to make sure it was compatible. Fron what i read the extra power in series 2 comes from revised cam shafts, and wanted to see if the ecu was revised to accomodate the cams. Cheers
Just letting you know from what I've found the s2 manual models have a different exhaust cam, compressor wheel and compressor housing compered to the auto s2 and all s1 models.
Would the different exhaust cam mean a different map in the ECU? Would this ECU still be ok for a Series 1, or is the tune very different?
Edited by Bugzs15
Most likely. Not sure if it will be ok for a series 1 and I don't know how different the tune is.
I recommend you get a tuneable ECU and tune it or pick the ECU that your engine came with from the factory if the car is stockish just for peace of mind.
ECU partnumbers:
http://webbersrbguide.com/index.php?option=com_content&view=article&id=58:rb-ecu-part-numbers&catid=45:wiring-electrical-a-ecu&Itemid=23
ok, so i looked at My copy of nistune in relation to r34 ecu's as I was curious.
There are approx 6 different image files, and this is the biggst difference i could find quickly comparing them. Alot were identical.
The timing maps had a copule of spots with 1 or 2 degrees different, wouldnt matter at all.
this snip is comparing 2 fuel maps.
i would call them the same....
you can download nistune as a trial, load them up into the main and comp slot, then click the magnifying glass to compare.
Thanks very much for confirming everyone, looks like it will be good to use.
Hope this post helps anyone else with similar question in the future as a lot of ecu questions relate to R33, but not many for R34.
I'd love to see some hard evidence that manual and auto have different exhaust cams and different turbos.
Series 1 are obviously different from Series 2. (compressor wheel from memory)
Edited by wolverine
  • Like 1
This is what I have found.
Exhaust cam on Nissan fast
August 2000 or newer (Manual only)
13020-AB000-
All other RB25DET Neo
13020-AA020-
Turbos on Nissan fast
14411-AB000-
May 1998 to July 2000
14411-AA100-
July 2000 to August 2000
14411-AA110-
August 2000 or newer (Auto only)
14411-AA110-
Alternate part number for 14411-AA100- is 14411-AA110-
Also found
http://2style.net/r34sedan/hikaku/hikaku02.htm
http://www.skylinesaustralia.com/forums/topic/69089-differences-between-r34-and-r33-turbo/#entry1527454
Edited by H4x
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
