Spotted a white 33gtst "33NSMO" at Norwest Business Park today.
Spotted you today too mate, near parramatta uni in the industrials... Nice ride man! :) I can't wait till mine is on the road.. not long now..
Terrys n1 32 gtr at the mechanics in faulco lol and a really really nice 33 gtr with the plates xxxgtr in penrith driving past my work on castlereagh rd. Have seen it a few times and it has given me happy accidents in my pants
Sorry mate haha
Saw a Bayside Blue R34 coupe on Day Lane, Kensington near UNSW at 3. The owner had just parked and was getting out of the car, I pulled up, stuck my hand out the window and gave him a hi-five.
This was me. Thought I'd finally stop lurking to reply to this.
Nice car man!
Edited by Wight
  • Like 1
Nice car man!
Awesome bro :cheers:
Do you study at UNSW? I've seen your car parked on that street a few times before.
Edited by Wordsmith
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
