im looking into upgrading my r33 turbos to the nismo n1 kit (http://www.ebay.com.au/itm/Turbo-N1-Upgrade-Kit-R32-R33-GTR-RB26-RB26DETT-NISMO-/120514498456) link to N1 turbos on ebay.
if i do get this kit will it be safe to put in my gtr i dont have a N1 block will this matter.
https://www.sau.com.au/forums/topic/445570-n1-turbo-upgrade-r33-gtr/
^ what he said, and they have bush bearings and may well be old tech laggy wheels. Just go straight to -7s (aka R34 N1s) or -9s. Its a lot of work to change turbos and they make a big difference to how the motor runs, so if you skimp you'll regret it. Only other option would be to contact Hypergear to what he has to offer, but usually the cost of a proper rebuild/highflow is too close to the -7s so its just not worth it.
There's no difference between the blocks with respect to manifolds and mounting of turbos.
... do yourself a favor and find a mechanic with plenty of gtr/skyline experience before you buy anything!
That kit is neither N1 nor Nismo however is a waste your money. As with everything in life you get what you pay for. What you're after is a set of direct bolt-on Garrett GT2860R-7s (AKA R34 N1). If you'd like some advice or a quote drop me a line.
  • 5 months later...
Hey Kudos,
I've got a 33 gtr. I was planning on upgrading the stock turbo's to -7's or possibly -9's though I noticed you have the 2871r-10's. Do you think these would be too small? I know there are plenty of threads on -5's vs 7's & 9's. Ultimately I'm trying to build the car for response and reliability. As guys who work on GTR's day in and out I was keen to know what you think the go would be??
Cheers
^ Do yourself a BIG favour - and research. -10s are the WORST possible selection you can make. Rubbish turbos, far too big.
Totally agree.
$200 turbo "upgrades" forget it - it's $2200 for a set of -9s or -7s or don't bother spending the money.
The N1 / bush journal setups are 1980s design, lack performance that has been well and truly superseded by more modern turbos and the extra response, power and performance is worth the money.
Turbos are the most important part, don't skimp on them or regret it forever.
  • Like 1
Hi jnbR33, as R31Nismoid the GT2871R-10s aren't a great selection for the RB26 and for response the -7 or -9s are the best option with the -9s being the most popular these days by a country mile.
N1 'upgrades' don't really fit into the word 'upgrade' as it's almost a backward step using out-dated tech and the only average-at-best performance you get from them.
R34 N1s however, good upgrade - but they are a "-7" turbo anyway really, so just buy new and don't worry about it
depends really doesn't it? if you spend that money on the parts how much would 2 rebuilds cost to be installed and balanced by a turbo builder? $500-600? probably alot cheaper than 2 new turbo's?? i'm not saying you guys are wrong i'm just saying they might be a good option for someone on a budget.
Well the cost would be roughly $1000 (worst case of course) for two turbos by the time you buy the parts, send them off to be assembled/balanced.
So yeah it most certainly is cheaper... But they are soooo much laggier. We are talking laggier than a -5 turbo (capable of 400rwkw) but they will only make the power of a -9s (340rwkw).
That's not really a good option in anyones books to have all the lag without the power. Pretty hard to justify that being an 'upgrade'.
You'd be better off taking the chance with a 2nd hand set of -9s for $1200-$1400 and getting them inspected.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
