Hey all,
I have been losing my shit while my car is in the paint booth with the weight of it not running right. Currently the car is running pig rich in the 10 afrs with a high idle and is spooling the turbo and stuttering past 3500rpm in the neutral position. It almost sounds like anti lag.
Having discovered this I since checked the TPS and replaced the MAF sensor, the new-used OEM MAF cleaned up the idle a bit and the car no longer died after any amount of throttle but the two-step action is still present. I have a new temp sensor on order, the only other thing that comes to mind is the Oxygen sensor but I cannot see how either would effect it so greatly.
Surely there are others who have overcome this, as I have read about others with the same propblem but with no posted fix,
RX,
Whilst Ben is probably right.........you would be well advised to put the useful bits of information in your post that would actually help people to understand your problem. Things like, what ECU, what ignition, has it been tuned, what were the AFRs under load when it was tuned? etc etc. For example, did you know that RB20s tend to run 10:1 AFRs when teh boost is turned up on the stock ECU anyway?
Yes that would help, it has a mines ecu, fmic, custom plenum, custom charge piping, bov, fpr etc. Stock ignition
It ran 12's afr's when I first installed the wideband whilst still running the oem o2 sensor. It always ran fine with a slightly high idle as my cold start and iacv share the same vaccum line. And it ran fine, after working on the body for a couple months I started it one day to it going in and out of rich and normal afrs. And now it will not pull itself out of being pig rich and 15 psi vaccum at idle.
Seems to me like it's not a boost leak as it shudders before it builds any amount of boost. Seems like it's running rich with on a retarded map.
Rx
You guys are a funny crowd, I've ran the car with no charge piping and it revs through the range fine whilst being pig rich, I'll figure it out sooner or later and post what the actual problem is. Thanks for the help I guess.
RX
RX
Your a funny guy, removing the intercooler pipework and refitting it without then pressure testing it.
When you find a boost leak be sure to report back.
So far I've checked the ecu and have got the 55 "all good", tightened all the silicone couplers for the charge piping but nothing yet, Thinking of loosening the BOV a bit, changing the fuel and changing the oil as there is a slight gas odour.
so you can't rev it past 3500rpm?
and your AFRs are super rich?
sounds like you need to check continuity between your ECU & AFM.
Also another worrying thing I've noticed.. you've got an aftermarket FPR & re-mapped/stock ECU.
How will loosening the bov or an oil change help at all?
Changes in vacuum? and oil filled with fuel can create an increased liquid amount could create blowby?
Anyhow I found that the red wire on the oxygen sensor was broken and repaired it, after the repair and having the car warmed up allowed my car to regain proper AFR's and rid itself of the choppy revs. It's quite funny that you were so sure of a boost leak that you went out of your over confident simpleton ways just to prove what you thought was a valid point!
To anyone reading this thread with similar problems besides this stagea fanatic , I would definitely recommend you check your o2 sensor with a multimeter.
BT
Thanks for the feedback.
In 90 percent of cases it is a boost leak. It is so easy to check for it should be checked anytime you touch the pipework.
Your suggestion of adjust bov and oil change is far crazier.
So is your car actually fixed? Or just idles nicer now?
Nope I drove it and It keeps proper AFR's whilst under load as well, I know neutrul rev's aren't the best indicator of problems and correct afr's but it worked well as a baseline as I knew where it should be. It runs rich in cold start and then you can hear a noticeable change in idle and then it run's 12's afr's after the O2 was fixed. Run's better than ever.
If your oil level is above normal and contains fuel, I would assume you will get blow by which could cause numerous problems no? Explain to me how this would not effect things please, rather than saying how would that work. I don't attest to knowing everything but I sure won't take your advice without explanation. I figured it was a good idea to change anyhow. I did not once say it was the problem but I new there was a chance it'd help.
Fixing the O2 sure does change afr's, I know for a fact it sends a reading to the o2 and at .5v would be supposed proper afr's at idle. I wouldn't think the ecu would disregard this at idle.
RX
You'd have to be burning an absolute shitload of oil for it to be a problem. In that case you've got other issues to look forward to. Yes oil collects blowby gasses but it is a very small portion of the oil itself and even less would make it back into the cylinder.
The thing is that the ECU doesn't even reference the O2 sensor at idle or at decent throttle. The ECU completely ignores what the O2 sensor says unless you're cruising at light throttle off boost. Soon as You've got some boost it goes back to open-loop meaning no correction based on the O2 sensor.
How did you decide that your AFR's are in the 12's again? Do you have an aftermarket wideband?
  • 6 months later...
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
