Fuel pressure dropping on top end. Looks like I have maxed the DW 300 pump. Time to add another pump to my setup (dang). I also found out why everyone adds a fuel sump to these cars as well. Right hand turns at 1/2 tank or less suck even at low rpms and speeds...total starvation there.
Already time for upgrade :). Time to see if I have any fuel pumps laying around.
If you don't ever plan on going with ethanol just throw in an walbro 460 and that should be more than enough. people manage to make 400kw with one and stock lines on ethanol, so if you are using 30% less fuel 500kw should be possible
That being said.... Still shouldn't have fuel starvation at half a tank, so it may pay to check your pump setup and that something else isn't dropping or constricting it when you're throwing the walbro in it
Will do. Thanks. I wired in a relay to the pump today (lol didn't do that yet) so we will see what happens there.
But yes starvation under right handers less than half tank.
Wow...
I'm embarrassed to say this but I feel like I should be clear to keep clarity with my build etc.
1) Don't EVER think the factory fuel voltage to the FPCM is going to keep up with ANY kind of uprated fuel pump. I have no idea why I didn't just hardwire a new relay in to start with, but I'm ashamed to say how much difference there was in flow. My car steadily dropped from 5500 rpms up (yes that low). No wonder why I thought I was running out of injectors. The drop was linear so I had actually tuned around it (not knowing), but at 6k it was 9.8 psi LOWER than it should have been and -20 psi lower at 7500!!! Even after rewire the pump is done at 7500 and is dropping 4.5 psi there and 8.3 psi at 7750. Some of this could just be the fact that I'm using the factory lines and some -6AN fittings at the ends. Perhaps running a straight -6AN to the rail would help...but I need to install a sump anyway.
EDIT - I am going to be testing more of this pump. I think my main feed from it was slightly kinked. I bet it will make 500 whp on pump no problem now.
2) Don't trust published fuel pump numbers. These are absolute limitations taking into account NO friction losses, etc. My DW300 pump is falling off after 7,500 rpms even after the rewire...again it could be from friction losses. I bet it's capable at the RAGGED EDGE of supporting 500 whp. It will be a lift pump from here on out and going to a sump with a real pump (walbro 460).
3) Be careful how you setup your Haltech engine protection. I had mine setup to let me know if I had seen 12.2 AFR (or leaner) after 10 psi boost. This way it's only limiting me from leaning out on top. It did NOT, however, catch the fuel pump issue! Meaning I was running 93% injector duty cycle due to the lower fuel pressure and still not touching 12.2 AFR. Since the rewire AFR's went to the 10's AFTER removing 15% out of the fuel map! I will now also have the fuel pressure set in my engine protection to give me advanced notice that I dropped fuel pressure below my target.
  • Like 1
That's a lot closer to what I would have expected to see from one of those pumps.
I'd strongly suggest doing a walrbo in tank if you're not going E85 and just keeping the tank above 1/3rd for all hard cornering activities. A little inconvenient sure, but its way cheaper, less stuff in the boot and way less noise than the external bosche options people do
  • Like 1
Yeah my brother has the two 044 on his turbo Mustang and damn you can't hear yourself think in that thing.
I did just get in the tank and found the cap had popped off the end of the factory fuel "sump". So there is my starvation issue for sure since the cap keeps the fuel from just rushing to the left. I put an industrial zip tie around it to hold it on (hey, they work).
Also reset my fuel pump angle in the cradle to give a better angle on the fuel feed lines (perhaps some kinking going on here?).
I will do the boost a pump before going sump at this point because I feel the car will likely top only 520 or so whp on pump.
Yes one walbro 460 would be perfect.
Removed carbon cannister (where my ps pump reservoir is now) and just ran a new line from the intake manifold using the factory metal line located behind the cam gears
  • Like 1
Thanks for that, I will keep the canister anyway but use the factory line.
Ok so I was tired of losing fuel supply and strange starvation at low fuel levels.
Here is my solution.
Integrated engineering sump with AEM 380LPH pump. Mounted under car and all plumbing is under car to/from factory fuel lines. I will add the check valve later and run a line to the front of the car, but I was missing a few things to do that.
So far ZERO fuel issues. I actually changed the fuel map after resetting the regulator and it started coming in nicely. This is a much better pump choice than what I had IMO.
Also added about 5 deg timing so far and the car is just waking up! I'll try to get back on the dyno soon enough.
Easy enough to make it bigger.
I'd toyed with the idea of a setup like that myself for quite a while but in the end a better intank solution came up so i'm going to go with that.
Weld an extension on it (plenty of space!) and she'll be apples for pretty much anything you can throw at it on 98 i'd think.
Thos tanks look nice but really are too small. If at full noise the lift pump starves that tank will empty in a second.
I thought that too at first...And yes I wish it was about double the size but if does have let's say 5 seconds of 100% fuel supply by itself with the assumption of 100% injector fuel usage.
The pump can't access the very bottom of the tank so you lose about 15% available fuel there. The pump uses about 25% of the total volume as well so really you're left with about 1 liter. Assuming no return from the rail with a 380lph pump you end up draining at a rate of .101 liters per second...giving me about 10 seconds before my listed safety factors. Engineering factor says 5 seconds should be solid.
Sneaky, make sure you are lifting in the tank somehow...any air sent up front was totally detrimental to my setup.
My brother and I took a road trip for the Hot Rod Power Tour and entered the car in the autox event at the Circuit of The Americas in Austin Texas. You'd never believe we took Fastest time of the day with only 2 runs! Yeah....that happened.
https://www.youtube.com/watch?v=j5CSFrnP_GU
Thanks to the Dose Pipe we were able clench the victory!
  • Like 1
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
