Yikes!
Makes me think of my drive shaft.
But man, the rest of the damage is nuts. How hard was the launch?
Full tilt launch on street. Broke immediately.
I'm on front nismo LSD so it goes pretty good but the only thing i can figure is the mounts sheared then the motor jumped and then the axle went. Yours looks insane!
Wow how did you do that?!
4
Very similar circumstances, but mine lasted 5 mins of normal driving after before the clunking started. :D
Fairly standard for OEM mounts to be shagged, break like that and cause similar damage... It sucks, I've been lucky enough to do it but my turbo hit the strut bar, ripped off the cooler piping and lost power almost instantly causing no real damage.
Nismo are much better but tend to cause issues with the fan hitting the shroud
Older ones but they looked and felt good. Strane to me where they both sheared where they are bonded to metal.
Don't have a video of this launch but do of others. I was just doing the burnout this time doing some testing.
  • 3 weeks later...
Installed all of it yesterday. Getting those motor mounts in was a total PITA. The fan shroud, however, was easy (didn't even need to remove fan or belt).
Nismo Engine mounts
Nismo Transmission mounts
New Nissan fan shroud
Used axle (New CV boots)
New fan shroud
Cranked the car just to get it running. Ran no problem but I need to fill the front diff fluid level today and then I can drive it.
Needed to lower the subframe on each side while jacking engine up to get mounts in - managed to do this with axles in and most components still hooked up but was PITA running pry bar and all by myself while wedging the mounts into place.
My advice now is if you are EVER getting at your mounts or removing/installing the engine do the nismo mounts right then!
sounds like fun! just make sure its got the early transfer case with no preload on it. (ie with car up on a hoist you should be able to turn the front prop shaft with no resistance turning the rear shaft.
or you will kill it in rwd.
the preload in the 33 and 34 gtr is from the attest computer, it's not mechanically different to the 32. But I reckon the 32 still wears its plates a little even without the preload factor when running without the fuse, especially when dyno tuning. As long as the front prop shaft is out you'll have no dramas with the transfer case running the car in rwd.
the preload in the 33 and 34 gtr is from the attesa computer, it's not mechanically different to the 32. But I reckon the 32 still wears its plates a little even without the preload factor when running without the fuse, especially when dyno tuning. As long as the front prop shaft is out you'll have no dramas with the transfer case running the car in rwd.
Edited by doo doo
i beg to differ... i have been around the block a few times with these things., but i agree, pulling the shaft is the best choice. fuse out and crack off the bleeder and if it still drags you need to pull the shaft.
Yeah I know you know your stuff, I recall this being discussed on here a few years ago too, and as far as I'm aware you can disable the preload in the 33 via the computer. Happy to be proven wrong, I rebuild the transfer cases with increased preload now anyway which means pulling the shaft on the dyno.
How to put your R33 in to 2wd (from the manual):
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
I have hooked mine to a switch in the centre console.
  • Like 1
  • 1 month later...
More dyno fun.
Finally moved my cam gears on the dyno. Spent 4 hours there yesterday (on a dynocomm inertial - which will soon be eddy brake). I now see what a V-cam would do for you. Moving my Poncam A's closer together (ie-more overlap) yielded undeniable tq gains with no appreciable drop in top end power (my 3" exhaust could be holding me back). I think it liked 8 total degrees of CRANK overlap (2 notches off from '0' on each cam) the best (Advanced intake 4, Retarded exhaust 4), but we did run add another 2 deg (crank) to the intake to bring it to 6 deg intake advance and 4 deg exhaust advance and this is where it stayed (for now). Super choppy idle now, but damn this car pulls like CRAZY now. makes 3 more psi boost at 4k rpms. When I compared 20 psi runs with cams set at 0 the tq goes to the stratosphere. Look at the differences from 4500 rpms to 7k! At 22 psi high number is now 653 whp and 515 wtq but boost control was shakey on these runs (oscillating from 22 down to 18).
It is making 300 WHP at 4k rpms on 20 psi...on 93 octane pumpgas! This is my 8374 EFR .92 IWG on a stock-bore 79mm BC stroker FYI.
58ab246eadbcb_DynoCamchangesconverted.thumb.JPG.403334239ea14914086aebe9dfb556eb.JPG58ab244687e7b_Lastdyno20psicamsset.thumb.jpg.a1565b209b5cae19e58f187a236c178f.jpg58aaff4ca6635_Justhighnumbers.thumb.jpg.e300231a1d0c3e828ae0fabf7265f6ae.jpg
  • Like 2
1 hour ago, SimonR32 said:
Those cam gear changes certainly woke it up!
I'm really thinking the stroker geometry and slow top end piston speed must REALLY like more overlap than I was giving it with these small Poncam A's and straight up cam timing. I just drove it again...damn car is an ANIMAL! I can not wait to try another 1/4 mile run in it! I can only imagine what a 3.2 with V-cam would be like!!!
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
