Like anything in the car world, theres always pro and cons. So what's the cons of using procam 260 10.8mm Vs. poncam 260 9.15mm ?? I believe OP and I want quicker spool so we should both go for 260 and higher lift possible for best gain.
Since both OP and I have to rebuild the head, I guess the difference in fitting these procam Vs poncam is negligible no ?
Poncam is suppose to boltin with no mods, suppose to lol
The procam will require new buckets - shims and the head to be "relieved" for lobe clearance
Look at contacting Unigroup Engineering for their 260 x 10.8, as much as their the same specs the UE ones open a lot faster therefore are peak open longer, will require new shims and head to be "relieved" for the lobes
I went from 260 to 250 poncams and would never use 260s again, 250s spool the turbos so much sooner and give more "drive" everywhere
Should add anything with more then 9.2mm lift will require better springs too
My 272 10.8 cams go alright hahaha
Still very responsive with my baby -9s
I would really like to see what happens if you where ever to put the UE 260 x 10.8mm cams in, those poor -9s would drop their bearings :P
Lift=power, duration=when
Please don't spread that... the reason for longer duration is not 'when', it just happens to be a consequence of longer duration.
Haha I know was considering it
But might be too aggressive for them
Going to bump the compression up when I get around to fixing my car
so in other words it's decides when it going to make the power
What I meant by my comment was the reason why people choose camshafts with longer duration is not because they want to make power later in the rpm range, that is just a consequence of a multiple of engine changes. As I said before, if you have low exhaust manifold back pressure relative to boost pressure (and this is usually in a high rpm engine ith big turbo that won't make a lot of power below 4000rpm... as an example), then you can choose longer duration camshafts to take advantage of scavenging effects during camshaft overlap.
XKALABA's result with going from 260 to 250 is not an accident, it makes total sense as he has factory mounted twin turbochargers that have high back pressure relative to boost pressure.
One example is on post #19 of this thread: http://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/
He makes 17 more KW and greater power everywhere in the curve from just changing cam timing...seems like a lot of power increase from rotating cams and from what I read most people don't move them more than a few degrees apart.
In the list of durations of "bolt in" cams there is clearly more than just 4 degrees of cam timing changes going on and it's leading me to believe that there should be more room in there even on the smaller turbos that I will be running to gain some response from changing out the factory cams and likely even more response when I get them timed right on the dyno.
Yeah but who is to say the cam timing was 100% set-up in the first place? If it was out, then very easy to get a gain like that :)
Really as the other guys have said - you are putting -7s on a 2.9ltr. Putting cams in, is a waste of time.
Your power band will be from 3000rpm-6500rpm regardless of what you do because the turbos will run out of airflow, as they run out around 7000rpm on a 2.6ltr. Hell it might even come on before 3000rpm... Not too many have gone and put such small turbos on a 2.9ltr, in fact I don't think anyone has.
...and you will choke the restrictive exhaust side.
hmmm, ok so taking all comments in this thread on board. I have -7's on stock RB26. Suprisingly the boost curve is quite laggy compared to stock (which is the opposite of what people say about -7's). Makes positive pressure below 3000, but I dont get full boost - 18psi until 4750-5000rpm ish. I was thinking Poncam 260 9.15mm lift to help bring on boost quicker and extract more torque early in the rev range.
I am now tossing up between Type R 250 9.15 due to some of the comments above.
Which makes more sense for my needs?
Stock cams on a 2.6 with -7s is best by far, i got my car with 260s and went back to 250s cause i couldnt find the stock cams :(, you need to get it on the dyno and dial the cam timing to get response, advance intake and retard exhaust
The result I got from the two cams where in my 34 when it was still a 2.6 with -7s, there is a dyno sheet here somewhere when it was last tuned with that setup and it would make positive pressure below 2k and usable boost in the mid 2k range ( in 5th cause 1:1 ratio ) and run 19psi to the 8200redline
What is your setup/mods and who tunes it ?
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
