How'd he get a s15 on p's? N/a?
I thought you had 2 beast cars ;)
You can drive the Aus spec one, the 200SX on your P's in NSW but it has to be stock
His however is the Autech version, i'd love an NA S15 too, they are a bunch of fun and sound amazing!
I've been having intermittent misfires and the typical coughing and spluttering over the last few months, it's been okay as i only drive the car once a week if that right now so it hasn't really bothered me, however my fuel pump has started making a mean groan which sounded absolutely horrible and before i got stranded somewhere with a dead fuel pump i thought now would be a good time to replace it
I came home from work this evening to a care package from Kudos, i purchased the Walbro GSS-341 (255lph) which came as a kit with everything required to install it into the stock position which is great if your car (like mine) still has the factory pump
With the street as my workshop and the sun as my light source i decided to start before it got too dark
Firstly i removed my old pump, be patient with this, be sure not to put too much pressure on the fuel level floater / sender unit
Here is a comparison of the new walbro compared to the stock pump
To fit the pump in with the stock fuel pump basket you'll need to bend the base off it, the little hook looking part flat, and then cut it off
Now attach the fuel pump to the tube which has the barb on it with the supplied hose clamps and new fuel hose
Attach the filter sock to the base of the pump and lock it on with the small barbed pin/circle clip
From here i used a Stainless steel cable tie to hold the pump to the basket to stop it moving around, people have used hose clamps however i didn't have a big enough hose clamp handy and the stainless cable tie works fine and looks great :)
After crimping the connections to the supplied plug i plugged the pump in, and reinstalled it back into the fuel tank and turned my car on to make sure it was all working.
Car is purring nicely now on idle, it's also feeling much more lively and less hesitant not to mention the misfire seems to have disappeared! All in all a cheap and good upgrade i would suggest to anyone who is unsure of the history of their fuel pump
Cheers, Jordy
  • Like 1
Christmas is gone and done, hope you all enjoyed yourself!
The car has been given some love. Over the break i replaced Oil w/ liquimoly oil flush and filter, Spark plugs and Coil packs. I also gave the AFM a clean while it was out
I then gave my new foam lance a go! what a cool idea!
Then i took it to family lunch and somehow survived from the city out to dural without getting pulled over, i did however see about 10 highway patrol cars.. that was fun. :P
Next up, clutch and engine swap i think! - Inter cooler kit is in the mail plane from japan so i've heard, hoping for it to arrive this week! - time to start looking for an EBC and ECU!
Came home to an absolutely huge box from Japan today which contained my inter cooler kit!
I Purchased the GReddy Type LS kit
Super excited about that, all i need now is a clutch and we can drop the motor in!
Edited by Jordy32
  • Like 1
I love this build :wub:
keep it up and keep us updated!
top notch bro.
my 32 has begun to seem a little sluggish and backfires a lot more than it used to.
nothing seems to indicate fuel pump but I guess its worth a check :)
  • Like 1
  • 4 weeks later...
Not much has been happening with the car, just gathering parts for my turbo swap, I've found an ECU and I've also been introduced to a friend of a friend who owns a fab shop who will be making me an Exhaust and a the cold side intake piping to go with the forward facing plenum
Enjoying the car honestly feels weird! - The R32 wanted to go and see his R33 friends so we went and said hello :cheers:
I had a slow week or two at work and was feeling kinda down so i bought myself an ARC cooling Panel for the R32, i love ARC, i love their story and their products so i was happy to pick up this piece, hopefully some more parts pop up that i can buy :)
This is something to smile about i guess
  • Like 1
Nice work mate, I always enjoy seeing a gtr kitted gts or gtst.
If I've read it right a rb25 +t should be a very nice upgrade over the 20de
Thanks! :)
I have an RB25DE from and R33 at the moment (which i found to be a great upgrade in itself haha) and I've just finished an RB25DET from an R33 which is going in in the next month or so
I was going to dabble with +T setups because it really interests me, but i ended up getting a plain old boring DET motor :)
  • 1 month later...
Woohoo! im back and with pics!!
Been a while since i posted but it's all happening!!
Took the car for it's last naturally aspirated drive to wisemans ferry, it was a strangely cold night and the car absolutely loved it, shame to think i was pulling the motor out the next day!
Put the Rb25 in my mate's stagea and set off to my dad's house who has a garage he's letting me use!
Just before she was pulled down
Front end and other bits off
Fluids drained and loom disconnected
Aaaannd, out she came!
Rolled the car out into the sun and gave the bay a nice wash
Went for a swim and had some lunch while we let the bay dry :yes:
More news when i get home! :)
  • Like 1
Had a few productive days on the car, going a little insane but that's alright
Tapped the old throwout bearing off
Pressed the new one on and greased the appropriate surfaces
S7wEzpAl.jpg?1
Got the clutch and related bits together
New Nissan Clutch Master cyl (Greddy Plenum in R32 with RB25 Clearance issues, apparently)
New Clutch kit
New Nismo Pivot Ball
New ARP Flywheel Bolts
New Nissan Clutch bolts
New Spiggot
While the engine was out i decided to install a GKtech solid steering spacer, mine was in surprisingly good condition already, but i thought it was a good idea while the engine was out! I also replaced my steering rack bushes, they where haggard.. Should feel much better up front with both of those done!
I put the new engine in, got my dad to give me a hand with that haha.. Engine wired up and pumps mounted it was time for bed
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
