Thanks guys :)
Planning on raising the car a bit and flattening out the camber over the next week, there is absolutely no grip in the rear... I spin the wheels constantly and well to be honest it's too low for my area, my lip has copped a beating since i'm not used to driving with it this low any more haha :whistling:
Also - Has anyone had any luck with the Whiteline swaybars? people say they don't fit, others say they do? not really sure what to do!
where did you get the frush exhaust gaskets from?
Hey mate hope you're well :)
I got them from GKTech
Here's a link for you - http://www.gktech.com/index.php/products/#26
I used the 3" ones throughout my exhaust even though it says "dump pipe to front pipe" and worked a treat! :yes: (http://www.gktech.com/index.php/3-multi-layer-stainless-steel-dump-to-front-pipe-exhaust-gasket.html)
Took the car for it's first drive to get some fuel and wash it, which was great! until i was driving home and floored it in 3rd, all was well until about 5k rpm when even though my foot was on the accelerator the car shuddered and fluttered and my boost gauge went straight to 0PSI, odd
Pulled around the corner to check for intercooler piping, no issues found, i started the car back up and the turbo sounded absolutely f**ked, like putting a bag of bolts into a can and throwing at someone f**ked.. i limped the car back home as i was only around the block.. :angry: ah well shit happens
Parked the car on the gutter and left it for a few days while i weighed up my options..
Got to work pulling the GT-RS out, i bought it second hand so this day was eventually going to come, i just thought it'd last you know more than a day.. :/ oh well
Made an absolute mess and spilt coolant everywhere, oops
Finaly it was out, the bearing was f**ked and was hard to spin, there was also a lot of shaft play
For the time being i grabbed a stock RB25 turbo from a wrecker and slapped that in
Works fine for now. Spoke to JEZ about it, he suggested just running waste gate pressure if i need to move the car at all but I'm going to be ordering a high flow R33 turbo to go in, and it's getting the tune fixed up next month :) took it for a test lap around the block and down to the servo, temps, pressures and drives perfectly fine, afr's are good but I'm not gonna push my luck
It's not all bad, the exhaust sounds great and i can have a conversation in the car without raising my voice!
Had a fairly chilled weekend, still waiting on my turbo to arrive so i decided to tackle some interior bits and pieces i've had lined up for a while but never really had the time or motivation to do which included the rear seats, passenger seat and installing some sound deadening. yes you read that correctly, INSTALLING sound deadening rather than removing it! :laugh:
For the sound deadening, i used these tubes of sticky foil and foam from Jaycar
I covered the whole back section from where the carpet sits, all the way up to the parcel shelf, unfortunately there wasn't much light in there so i couldn't get a clear photo.. I took the time to neaten up the wiring while i was under there too which will help me sleep a little easier
I then pulled the old GTS-T Rear seats out and replaced them with much better looking, feeling and cleaner GT-R Rear seats
After putting the rear seats in and giving them a once over with the vacuum cleaner i put a GT-R Passenger seat in to replace the old and boring looking GTS-T seat which is much more comfortable
Always feel good getting those little jobs done, and for only an hour or two of my time on a lazy Sunday the difference is massive.. Really happy with the interior now, i'm going to look at some speakers for the door and sound deadening in there too as my speakers are missing.. :rolleyes: weird..
Cheers :)
  • Like 1
hey mate
how do the 17x9+22 sit all round? inside / outside / flush with front n rear gaurds?
Hi there :)
Fairly well, flush with guards with some guard rolling and camber but my car is fairly low :/ - I'll be looking at a 9 +30 in the near future so i can fit a wider Tyre under the guard but a 235 fits
No issues with brake or coil over clearance at the front or rear though
  • 3 weeks later...
Got a tune booked this monday with JEZ to touch up after installing my highflow, so in the meantime i've been doing little things to the car while we wait
Up next on the list was the clutch pedal bracket.. A fairly common issue with these cars, and i wanted to fix it before i got stranded
I went ahead an ordered a Nismo Clutch pedal bracket, the Nismo item is made of a thicker steel and has some extra welds to strengthen the unit
In the box, you get a clutch pedal bracket, and an instruction booklet which is all in Japanese
Here's a photo of the unit, you might be able to see the difference in thickness, you can certainly feel it when they are both out of the car
I went ahead and pulled out the clutch pedal bracket from the car, and unsurprisingly i found this..
A clean break, there's a lot of evidence that someone has tried to fix this in the past as there is weld and spatter all over the unit, but all that seems to have done is moved the stress to a weaker part of the bracket
Here's a comparison shot of the 2, as you can see the nismo unit has had that area boxed in, i can imagine it flex's a lot
I assembled the pedal, spring and little switch and put fresh grease where i found old grease and reinstalled it
I'm happy to report a world of difference, the pedal feels great and it no longer sounds like someone is bashing the firewall with a hammer whenever i try to change gears! - Thankfully the weather is warming up, working in the open air at night was getting pretty average, but it's warming up and the sun is staying around for longer so I'm happy
It seems my GT-R disguise is working :ninja: lol!
I got it from RHD japan, i didn't know they didn't release one for the GTR, is it a common problem with them too? Seems odd they wouldn't release a GTR version don't you think!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
