hi guys,
I'm a newbie in R33 suspensions area..
I would like to ask a question about R33 springs..
last month, I've bought 4pcs Tein Lowering Springs from someone via online..
he said those springs could fit on R33 GTST or R34 GTT stock shocks..
because of my car is R33 GTST so I thought there were not problem at all..
then when my mechanic tried to place those springs into my stock shock, those are not fit..
those springs are too short for my stock shocks..
my question is, where's the problem?
are those springs has been cut?
or R33 GTST and R34 GTT are not having the same springs type or size?
cheers guys..
https://www.sau.com.au/forums/topic/448904-r33-or-r34-tein-lowering-springs/
Im taking a guess here, but i reckon your mechanic just meant that stock shocks do not support lowering springs. "springs too short for shocks"
You bought lowering springs, hence why he said that.
That being said, if you are keen on using the springs on stock shocks, its 100% compatible, with the only down side being your shocks sit half way compressed.
It's still better than doing it the ghetto way (people with cut/heated springs on stock shocks)
Edited by Deza3000
You probably bought springs for aftermarket dampers/struts. Did you get the spring diameters?
no I don't get the diameter, but maybe I can measure it..
is the R33 GTST and R34 GTT have the same type and size for springs?
I just guess my springs have cut before so it makes not fit for the stock shocks..
Im pretty sure the spring types are the same but the shocks would be different, cause r34 use both fork types and eyelet type shocks where as r33 just use eyelet?
Anyways as i stated before, you must have purchased lowering springs, hence why your mechanic says the springs are "too short", cause they are lowering springs. The only way to lower a car on springs is to buy springs shorter than the factory springs....which is what you have done. Factory shocks are built for taller springs, however most people still use factory shocks on lowering springs anyway so you should be fine. If you plan on doing some track work then id recommend getting some good shocks e.g. bilstein or kyb. It will still work with factory shocks, you will just have a rough ride with a chance of bottoming out.
you didn't buy them off the seller on SAU by any chance did you? the guy that was selling Tein lowering springs for r33/34 that he said have been cut....? becuaee if you did then yes it would be safe to assume they have been cut...should be easy enough to see anyway
yeah, lowering spring still fit with the factory shocks..
but if it did not fit, the only possible way is the springs have been cut..
he did not say anything about cut the springs..
when my mechanic said "too short", we were realised there's cut on the springs..
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
