C34 Adjustable Front Radius Rod/caster Rods
DaveB
 Share
Can somebody please tell me *definitively* (ie. with evidence) what the difference is, if any, between 2WD and 4WD adjustable tension rods?
I have had some sellers tell me that these rods will fit 4WD:
http://justjap.com/hardrace-heavy-duty-rubber-bushed-adjustable-tension-rods-nissan-s14-s15-r33-r34-2wd.html
When I look elsewhere, the only ones I can find advertised for 4WD are all pillow-ball, and I want bushes.
I can't imagine what the difference would be, having seen both the 2WD and 4WD factory original versions, but I suspect there might be a bend in the 4WD versions which isn't present in the 2WD versions... can anybody confirm one way or the other?
cheers
DaveB
There is no way Driftworks (and everybody else) would make two different arms if one would do:
http://www.jdmgarageuk.com/suspension-braking/adjustable-arms/tension-rods/driftworks-gtr-tension-rods.html
I think there is a bend in the 4wd and you could also measure the overall length and the distance between the two bolts.
I wouldn't be buying the 2wd version.
Ikeya offer the choice of pillow or standard bush but its top quality gear and priced accordingly (although strangely the WGNC34 is priced cheaper than the GTR one although I am pretty sure its the self same item!):
http://www.greenline.jp/catalogue/bproduct.php?type=suspension&subtype=Rods%20and%20Control%20Arms&brand=IKEYA+FORMULA&series=&name=Tension+Rods&fromlink=1
Dave, I would need to take a pic of the ones on the Stagea but I can't do it till Thurs. I also have a set off my R33 sitting in a box at work, so I should be able to post up pics of both. I thought there was a difference between 2WD and 4WD versions but I have never compared them directly so I am going off what I have been told.
Good point. Yes, in that picture of the Driftworks rods I can definitely see a bend. I don't have any to be able to measure the distance between the holes though. That pricelist you posted shows the different models pretty clearly, cheers for that.
Pics of the two would be awesome. I'm assuming that GTR is the same as 4WD stagea, same as Bob. Is your R33 GTR or GTST?
Hole spacing might be the issue from memory.
Push comes to shove I can take the rods from work to the workshop and compare them directly...but that will be Friday morning.
It was so long ago I can't remember what is what. I seem to remember the Stagea had R33 GTR suitable rods. The ones in the box are R33 GTS-t.
Sorry I got waylaid with brake issues, another story. But I held the arm up to the stock ones and I can tell you that the length and hole spacing at least appear to be compatible. I will have a go at fitting them tonight, since the car is already up on stands without front brakes. Should be updating this thread in another couple hours or so :)
Well, looks like they're not going to fit.
Here is one of the Hardrace arms next to a stock arm:
First thing I noticed was that the captive bolts were shorter. Unfortunately, even though the spacing is correct, they're not long enough:
There's also a very slight bend, which I don't think is crucial:
...but without it, the swaybar links get rather close:
...there's not actually much space there now:
Another issue, is that the bush end appears to be too narrow - pretty sure this would just be clunking back and forth on the bolt:
So, unfortunately I'm going to have to try to return this and exchange for a pillow-ball style arm, because they're the only ones I can get. Doesn't look like I'm going to get that 7 or 8 degrees of caster any other way.
cheers
DaveB
So I've spoken to the seller, and it looks like these are the ones he should have told me about:
http://www.hard-race.com.au/index.php?route=product/product&path=25_717_731&product_id=845
HardRace advertise them as R33/R34 GTR and the picture shows they are visibly different to the S14/R33 type (including, apparently, longer bolts). They also appear to have a slight bend... but it's hard to tell.
Bob, I'm really hoping that since you've got a GTR rod in yours (which is 4WD), these will fit as well since they're for GTR.
Oh well, have to wait another week to find out I guess.
Great news, thanks Rob, confirms the details I found on the Cusco arms here: http://www.rhdjapan.com/cusco-adjustable-pillow-ball-tension-rods-nissan.html
Just out of interest, what is the piece of flat metal with the bolt holes which is welded onto the side of the Cusco ones for?
No idea - mine doesn't have it. Here is a pic from the Cusco web site:
http://www.cusco.co.jp/en/catalog/pdf_catalogue_suspension_parts.html
  • Like 1
Ah k looks the go I have rose joint type hard race rear camber arms and rubber bushed hard race toe arms. I've only seen the spherical bearing type castor rods but clearly they make bushed ones from the link on here, much prefer the bushed ones should last longer.
Edited by roboat
  • Like 1
  • 4 weeks later...
Thanks Bob, I can confirm that the R33 GTR Hardrace arms fit RS4 :)
(pic in post above)
Wish I had've got this right the first time around, but oh well. This upgrade is not actually much more expensive than bushes (actually cheaper than what I paid since I did it myself this time). I will have to wait and see if I can get my 7 degrees of caster out of them though - the arms didn't actually need much lengthening, so they won't go much shorter to gain caster I guess.
Well, the arms definitely fit, but after taking the car in for an alignment, I only have about 4.5 degrees of caster... About as much as I could manage with caster bushes. Apparently the arms are at their shortest. Sounds like bad design to me - who would be buying adjustable arms to get *less* caster? Or have I missed something?
Wolverine what is the plastic that you needed to move forward? Also, what traction rods have you got with 6 degrees?
 Share
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
