After thinking over and over again and due to personal and unforeseen circumstances - it will be wiser for me to let my GTR go if the offer is fair - looking at $33k negotiable. No time wasters please... Ad is only posted on SAU and nowhere else...
No expense spared on this GTR - buy give her a remap and be happy driving her... Very reluctant but you gotta do what you gotta do... If she doesn't sell before things pick up - then i guess she was meant to be mine..
Car is in very good condition - Year 89 - Chassis is Accident Free - NSW Rego: THE.32R - till May 2015 - Gunmetal Grey - has 155k km on the clock - but i do not know the mileage of the engine - it is running well - car is currently at JLM putting together the final touches and putting the Motor back in...
Text me at - zero four three one six two one seven two six
RB26DETT :-
CP Pistons
Eagle Rods
HKS cams
Springs/Retainers
HKS Downpipe
Full custom tucked 3.5" exhaust and high flow cat made by Fabulous Fabrications (beautiful work) along with custom Hot/Cold cooler pipe.
Intercooler
Splitfire Coil Packs with New Harness and extra Grounding
Haltech Platinum Pro ECU
Bilstein (Yellow) /Eibach strut/spring combo - No leaks and no knocks
Ikeya Formula front and rear upper control arms.
Front and Rear Apexi Dry Carbon Strut Bars
Cusco Swaybars Front and Rear
Cusco 1.5w rear diff, fully rebuilt and new diff bushing installed with newer (and slightly larger/stronger) R33 half shafts
Diff oils all changed - front and rear less than 5k km
Gearbox - Redline Anti Shock Gearbox Oil (Smurf Blood) - less than 10k km
OS Giken Twin Plate Clutch and Flywheel
HICAS delete
Nismo LMGT4's with 265/40/18 Federal RSR all round - less than 1000km
Nismo Wheel Nuts
Apexi AVCR
Nardi Deep Corn
Nismo Gearknob
Full 3M Tint
HID Headlights
C's Short Shifter
Parts just installed and travelled - 0 km - being put together and putting the Motor back - 100k km service with extras
Brand New - Garrett -5's
Brand New - Cometic Exhaust Gasket
Brand New - Nismo Mounts - Engine Left, Right and Gearbox
Brand New - Nismo Clutch Slave
Brand New - HEL Braided Clutch Hose
Brand New - Nismo Thermostat
Brand New - Heater Hoses and Radiator Hoses - Silicone
Brand New - Gates Racing Timing Belt, NSK Bearings and Cam Seals
Brand New - Water Pump
Very clean, GLWS! Hope everything is ok, always sad to see when someone has to let their pride and joy go due to unforeseen circumstances =[
Thanks mate - yeah is ok - just taking a step ahead as precaution in case of anything =) Its a slow market out there...
My old car.
One of the things to note about this is that the chassis isn't like a golf ball and the sills are very straight.
Since I sold this car, I've been in the market for another one and very disappointed with the chassis' that I've seen. I didn't appreciate how clean it was when I sold it.
  • Like 2
  • 8 months later...
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
