Haha yeah, I'm all for having a laugh at myself but there has to be a line in the sand at what's funny or not and that crossed it I think
Well he does drive two really fast cars and a silly fast bike so he might be compensating for something :/:D
You have to be careful what you write, you never know WHO will see it, haha :woot:
If that's to case I think I need a few more really fast cars and a couple of big Bikes :yes::yes:
I remember seeing the video of this, bought a tear to my eye watching it :(
Reading this it reads like you think the guys building did something that cause it ?
there is a video ?
Fancy having to watch it over and over again, no thanks :no:
Experience Peter, I was sitting in a HQ ute while one mate was filling up and the numbnut next to me decided to play with a lighter just rolling the wheel on the flint
It ignigted the fumes in the cabin (Boom!) and lit up the filler neck. The attendant refused to come out with the extinguisher.
So I went back over after about 30 seconds and put the cap back on which extinguished the flame.
(Only the fumes were burning from the filler neck.)
We all lost eyebrows, some hair and a few years.
Farkin idiot
Sorry no vid ...
Fark, you blokes were lucky, it does not take much to cause what could have been a lot worse.
I had a 1936 Dodge when I was a kid, had just filled it up and was going like a DH , lost it and wrapped it around a light post, bent it in half , we all got out OK, well sort of OK. Petrol all over the place and my mate lit a smoke, everyone shit and he threw it on the ground, yes into the petrol and it went out, windy night no fumes I guess but it scared the crap out of me :nuke:
Yer thought I would go to my local racecraft engineer to get some end links made for my sway bar. I gave him the instructions & measures. With rose joint ends , a short and long extensions for a soft and hard setting. Left & right handed threads with matching locking nuts and tapped spacers. You get the picture, and a price tag to match. Only to find out later none of my measurements even came close to working . Engineer says to me try these, a male and female rosejoint screwed together 40 bucks.
  • Like 1
release bowser handle (natural reaction) and close lid (unnatural reaction) when fuel neck catches alight
maybe difficult to comprehend if first time and/or fear sets in
Man i wish i knew that, at first i thought the whole servo was going to blow up. But 2 seconds after I didn’t care.
I was more worried with saving my car then anything, i understand the servo attendant did not want to help but heck i just wanted my car. He could have at least given me the key to the fire exinguher box, i asked him like 6 times and was yelling at him towards the end.
Even the firemen said what the hell why was there no key in the box as that’s not compliant by fire safety standards. Also it was blocked by the servo bin that they have were the water bucket ect is.
They now have a key in the box, the break glass section is removed so even quicker access and no obstructions, yet they still claim no fault at all.
It took him like 2 min to hit the fuel cut emergency button when i ran in and told him there was a fire, he didn’t believe me.
The funny thing about the fuel vapours is. The servo was only renovated 2 weeks prior, it was the first service station in Aus to have this new technology installed that has a vacuum in the nozzles to suck out any fuel vapour.
I remember that for next time and I will have my own extinugher in the car.
Yes and no, two different mechanics built the car and put it all together. Then a separate tuner.
I had also taken it too another two mechanics locally to get a few small things fixed up, i.e. catch and BOV issues and they never picked up on anything
I had also filled up about 5 times prior to this time so I was not expecting it
My worst modifying experience would be when i was being bloody ignorant by using only a scissor jack to hold up the car while changing my brake pads. The jack snapped and the car plummeted onto the rotors, luckily my foot wasnt under the car and my expensive brembos didnt take a hit. Since that day i bought 2000KG axel stands and 1800KG hydraulic jack as well as watching countless number of youtube vidz on how to properly jack up a car.
I've only got a scissor jack. do carry your hydraulic jack in your car at all times? aren't they big? or do you just use scissor for spare tire change? and hydraulic from home.
Throw a wheel under the car, under the sump or something. Will stop the car from Crushing you if it falls. I have had a car snap a jack as well. Always have something as a failsafe.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
