Ryco filters are ok;
This is from the M35 info thread, looks like your HR uses the same filters as VQs
Oil filter is Ryco Z436 or Z445 : Nismo (Veruspeed) 15208-RN010 : K&N: HP-1008 : Amsoil Ea012
z445 - seal diameter 63mm, height - 65mm, seam diameter - 68mm, thread size - M20-x1.5-6Hmm
z436 - seal diameter 64mm, height - 66mm, seam diameter - 69.50mm, thread size - M20-x1.5-6Hmm
So either of the rycos is ok since they're almost the same size, IIRC one is cheaper.
  • Like 1
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7418379
Are Ryco oil filters any good ? What's the correct part number for the VQ35HR ? Some said Z445 and some said Z436 ?
For some reason, the ryco webpage lists a Z436 for the V35, but Z445 for every other vehicle with the same engine, including the 350Z.
Most other sources list the Z445. The Z547 also fits, but is 20mm longer
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7418579
  • 8 months later...
I've got about another 250kms left until I'll be due for the first service since I've owned my V36.
I've been looking at the Martini Racing Oil line, but can't seem to workout where to buy it.
What are the current recommended good quality oils I should be looking into?
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7585747
That's a fair point, but I bet these days its unlikely any of the oils sold are likely going to cause an engine to self destruct.
I ended up referring to another forum bobistheoilguy.com and think I'll settle with an oil I can readily pick up from autobarn etc relatively cheap at $85 for 5L that seems to have good feedback from used oil analysis tests and users in general. Looks like I will settle with Liqui-Moly 5w30 Leichtluft special LL (seems Nissan run liqui-moly in their bathurst 12H GTR as well) and I'll run genuine filters.
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586405
I have been using Castrol Edge 5W-30 for years.. I just wait for one of the local auto stores to have a special on for around $40/5L and buy about 4 of them.. I use the same oil in my wife's J31 Maxima.
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586463
Maybe ill get crucified for this but I've used Castrol Edge 5w-30 for 4 services and found that the engine wasn't as smooth and fuel consumption was a tad worse compared to the Motul oil I am using now. Could be due to other factors that I am unaware of. So now I am sticking to Motul. But I am open to suggestions and trying out other oils as well.
I think some people swear by what they use cause their mechanics use specific oils and tell them how good they are. At the end of the day comes down to personal preference....imo anyway
Edited by colin.ssc
  • Like 1
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586499
yeah, I think a lot is personal preference. in my last car I tried lots of different oils (of the same weight), and couldn't detect any difference between any of them in terms of performance or economy, so these days I just stick with a reasonable quality oil that doesn't cost too much.
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586807
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
