Hey I'm new to sau, bought a series 2 R33 Gts-t and I'm wanting to high flow my factory turbo, I've looked through a whole bunch of threads but haven't really found any specific measurements for the diameter of the compressor wheel. I'm fairly sure the stock wheel is 49mm and I'm wondering how much bigger of a wheel can the housing fit? Also I'm unsure of the total height of it, if that makes a difference? Thanks heaps
https://www.sau.com.au/forums/topic/450722-high-flowing-turbos/
I got a turbo highflowed by GCG about 6 years ago for nearly $2k.
Would choose Hypergear today (if I were in Aus - actually have a top turbo man locally) - continuous development, better prices, feedback.
What are your:
a) Goals (ie just a bit more top end power, whilst retaining some low RPM response)
b) Existing supporting mods
c) Budget
Goals power wise I'm looking for some 250+kW at the wheels.
Supporting mods, nothing at the present time apart from 3" cat back exhaust, pod filter, adjustable boost controller. However I do plan on buying splitfire coil packs and new spark plugs. As well as a new ECU, thinking of tuning it to run E85 but since I'm in canberra there's not many places to get it so I'll need it to be able to read both ethanol and octane.
Budget is around 2-3k willing to spend more, just need more time to save the money.
they are two of the main companies well known in skyline community which provides high flow service
there used to be a few more some years back, but they are either out of business or just stopped doing them
there's also precision turbo in Wetherill park NSW that does high flow as well. Having used high flow turbos from all three companies I personally prefer hypergear if you're chasing power on a budget, precision is also good as well but they do cost a little more for their ball bearing high flow, which gives a good balance between power and response,
good thing about hypergear is they are constantly R&D to improve their products like what GTSBoy said, their latest highflow design is a more competitive product than the GCG high flow I think
If you're replacing the turbo yourself, set aside around $1k for a turbo. The standard r33 high-flow from hypergear is a fairly proven item. I use one as well. Keep in mind you'll probably spend a few hundred more on gaskets and a new set manifold studs and nut kit. (might as well fix the manifold while the turbo is off)
Is your vehicle supported by nistune? If not then you are looking at an aftermarket flex-fuel capable ecu. The cheapest would be an adaptronic e440d. Even if you get that at a good price, with the accessories (air temp sensor, ethanol sensor, loom) you wont have any change from $1.5k
Then factor in +$1k for a GOOD tune, where the tuner has paid attention to partial throttle drivability and fuel consumption. That would be a single tune on one fuel, that wouldn't be a flex tune with runs on 98 & e85.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
