If ya'll could keep an eye out for my motorbike, it was stolen by scum of the earth today (Wednesday). Thank you.
2008 Raven/Black R1
Rego: HG165
Stolen from Boronia between 9am and 5pm 26th November
Identifying features:
Black windscreen
Yoshimura slip ons (reasonably loud)
Black Yoshimura rearsets
Black Pazzo levers
Green parker bulbs
Gold accents (bar ends, caps etc.)
Fender eliminator
Fast blinking L.E.D. turn signals
Passenger pegs removed
https://www.sau.com.au/forums/topic/451119-stolen-motorbike/
Old mate ian is prolly just a bit upset about the smackdown he received in the wasteland for putting up an ISIS flag as his avatar and forum signature - as you can tell, he's all about sensitivity. Obviously went through topics I've started to try and find any dirt he could cling to like a parasitic barnacle.
To give ian and anyone else reading this an update, my bike was eventually located
http://m.heraldsun.com.au/leader/south-east/motorcyclist-dies-after-colliding-with-car-in-dandenong-north/story-fngnvmhm-1227142964185
  • Like 1
Wait so the thief died?
Karma at its finest.
Pity the bike was probably damaged in the process.
Probably? Any motorcycle accident that kills someone invariably damages the bike :)
Particularly 170km/h impacts
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
