Here is my 7, original 76,000k's with a 2.3L Manly stroker kit, HKS cams, Hypergear highflow into 3.5 inch dump, Carbonetics twin plate clutch, T slot rotors with race pads. All ready for the Sandown track day tomorrow. :)
It made 270kw at 20psi, very responsive stealth setup. Should be great fun on the track, but it still needs major suspension work.
  • Like 4
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7433642
Have you taken that thing done the strip?
Not yet. Just waiting on some Yaris coils to run moar boost. It's getting set up for track, but I am sure it will run good times at Calder. I am a little worried about dropping the clutch at 6k though. :P
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7433778
How did it perform on the track ? Did you have any problems with AYC running that much power?
I had a ball, Sandown is a fun track but hard on brakes with 3 big stopping zones. The full floating disks and 800 degree pads could have got me through 20+ laps they were that good.
AYC? Not sure, it seemed very stable in the corners with the A048 semi's, never stepped out even on tight corners, and although there was torque steer, it still went the direction I pointed it. Very Go-cart like. :P
2nd gear was a waste of time, cornering in 3rd seemed fastest without wheelspin. 4th gear syncro's are a little grindy at 7k revs. It's the only gear I have issues with, and only at high revs. Might be getting a bit worn.
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7434751
Oh nice! I need to do some more prep work before taking mine to the track ==; what brand were the pads/rotors? Project u by any chance?
AYC must be in top condition, otherwise you'd have an open rear diff :P Were you on coilovers? Haha yea evos come out of the factory track ready
Is your tranny on its way out? Old trannys with a built motor would reveal some of its hidden defects/abuse :P. Mitsubishi chadston parts and service sell brand new 5 and 6 speed transmissions for evo 8 and 9 with overnight pickup, think they go for about 3k if you are interested. Should fit a 7 considering its also CT9A. It would probably cost the same as overhauling your current one. Probably get it cheaper online, but yea something to think about in the near future.
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7434762
Pads and front rotors were from Ivan at x3e motorsports, great guy.
No coilovers yet, although the factory ones are a little clunky sometimes, definitely time for a set. I was looking at MCA or Shockworks, but I am yet to do my research.
At least the boxes are reasonably priced. I have the 5 spd, but probably need the 6 if the final gear is longer, are they just as strong? I was nearly topping out 5th at Sandown. At Phillip Island I will probably run out of revs. I may look at rebuilding the current box myself if the syncro's are cheap enough...
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7434811
Yea mine were pretty clunky to, especially around the bends, not sure if was worn rubber mounts or just worn shocks, invested in HKS coilovers, probably wont be as good as MCAs though :P Those are proper track spec!
Yea the gearbox goes for a good price, but unfortunately the 6 speed is rather weak compared to the 5 speeds, only good for about 400-450whp. 5 speed boxes are known to be much more durable, the track spec evo 9 RS had the 5 speeds, while the standard 9 GSR and MR had the 6 speeds. Not sure how the gear ratios are on the 6 speeds though, they top out at around 280kph.
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7435062
Mine needs a brake pad replacement and new clutch soon. :(
Pretty much stock except for removing restrictions in exhaust, lower IC pipe, turbo hotside pipe.
Trying to 'hide' amongst the crowd.
It's a nice daily.
Very nimble & stops on a penny.
I've enjoyed your anecdotes above!!!
  • Like 1
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7435070
I have 2 excellent pics of an EVO and how they should end up,,,HA HA end up,,,I'm a funny bastard.
Sorry for the poor picture quality,,,I'll try and do better next time and there will be a next time.
Cheers
Neil.
  • Like 2
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7435101
It's a nice daily.
Are those bilstein shocks i see ?? :P Were those factory fitted on the MRs? I originally wanted those shocks with lowering springs but they cost too much! 1000 dollars for 2 :/
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7435128
Not mine but if I had stayed in Fiji a bit longer I would have bought this. A genuine bone stock Evo 3 GSR! One owner in Japan & it was imported by a local drag racing champion for his daughter..
Now it is owned by a crazy fellow who loves Evo's. Amongst his collection of the only Evo X and a 8sec Evo 2, he has turned this E3 into a 10 sec streeter...
Cheers,
Raj.
https://www.sau.com.au/forums/topic/451166-post-your-evo/#findComment-7435148
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
