So to add another view:
Used PFC $800
New Haltech $1800
Dirty 30 + pistons + rods and hone $2k
Hypothetical, if you can do all the work yourself bar the hone.
5hp for the haltech (if that) Vs 15% tq min for the RB30
It's not about the extra hp, it's the features and how much nicer it drives
It's like comparing a 500hp HQ and a 500hp VF commodore I know which one I'd rather drive every day
  • Like 2
Used PFC $800
New Haltech $1800
Andrew Hawkins R32 gained 20+ awkw just from changing to a haltech. And as previously said its not just about peak power it allows closer and more accurate reading of things like knock which means you can add more timing and boost. It also has much better drivability on the road.
Having said all of this you'll never know the difference until you actually try it. I love my haltech and I'd never go back
Used PFC $800
New Haltech $1800
This is what scares me when I think about the money I have just spent on new turbo, manifold and now ECU to come
just doing the maths on the changeover from pfc to haltech, lot of coin
$3k for supply fit and tune ecu for flex fuel
walbro e85 pump supply/fit $400
flex sensor supply/fit $470
external 4bar map sensor supply/fit $250
E85 fuel & flush $200
optional:
oil pressure sensor supply/fit $330
optional:
Agreed, this was my quote:
Haltech Platinum Pro ECU (rrp is $1995)
Installation of Haltech $125
S&F E85 Sensor and Haltech I/O12 expander module (required to get the sensor to talk to the Platinum Pro) $1095 fitted
3 Port boost solenoid, supply and wire up to haltech and setup $350
Tune Haltech on 98 octane $800 (normally $1000)
Tune Haltech on e85 $800 (normally $1000)
$5,165 including tune....wtf
Quote is from a major brisbane tuning company
6C859AB6-5CA1-436B-AA65-873DBAD76007_zps
Without crank trigger
31EDDFD0-69B7-4BD8-8267-31B5B0438C21_zps
With crank trigger.
I can't remember now if the without crank trigger was done on the FC or the Link G4, it's been a few years since I put that on. Either way, that timing variation with the timing taken from the CAS is woeful at best.
Both graphs taken from my own car.
Yep it's not good. This is the issue with a newer/faster ECU mating to old tech/speed of the CAS however.
Using like for like (PFC/CAS), PFC isn't actually seeing said variation... So you aren't actually having a problem with timing.
There is no peak to be gained.
As much about dyno variance and a tuner putting in a bit more time than anything else.
To answer your original question, outright power wont change, tuned exactly the same peak power and tq is governed by engine spec, condition etc.
Everything before peak power the difference can be minimal to 20hp in certain areas (although very rare). The newer ecu's have some compensation tables which help with drivability. 5Hp is noticeable to most in off boost power
Then it comes down to features, pay more you get more. If you hardly use them, your paying for wank factor. If you compete with your car and have a dog box or better, launch and flat change will be worth it. On a street car you will eat syncros if used often. So start going to the gym now so you can do a gearbox R/R by yourself.
The only time more map resolution is of benefit is when you have something funky going on- more common on NA engines with harmonics. The director of a large ECU company told me many years ago that they can do 100x100, but its just time entering zones repeatedly and at a starting price of $120 per hour for tuning it will add up.
On the street (and forums or even friends too) there is a lot of "you should" this and that and in a perfect world where money/time, car off the road is no object, sure! For this reason, anyone who asks about my car, its stock with an exhaust and im happy with it, I don't have to listen to their BS or questions.
If it was me, I would use the PFC and go from there. Why? Because I know guys who can map one from initialize to done in less then an hour which includes a lot of drivability and economy stuff. Sit it overnight for cold start and its done. Then go from there
Best post in this thread.
For me the deciding factor comes down to the need (or not) of auxiliary/extra inputs. AUX for things things like a E85 flex-fuel tune and so on. If you don't plan on that, then there is not a lot of benefit to spending $1500+ on the change over.
New ECU & inputs etc - $1800 - $2200
Tuning - $600+
Minus resale of PFC - $600
Leaves around $1500-$1800 depending. IF you wanted E85/Flex (or things like launch control, oil temp/pressure ECU cut out), it is total no brainer - change the ECU 100%.
We all had the powerfc and that was the cause, even piggaz who got brand new nismo afms had the *cough* no dry solder there
Interestingly my PFC Pro never had that issue.
My original PFC did, but it was once every 3-4 months (and I drove daily). Hell my current car, 18 months old, has more coughing/shit bugs
same here, running PFC Pro at the moment, never had any hiccup
Cmon man, Andrew Hawkins.
I wouldn't be so sure with that, man. Terry had huge timing issues on his blue R34 GTR (PFC) years ago.
I may be wrong but I'm sure my 34 with PFC has Z32 afm and 2 map sensors? I know 1 sensor is used for the boost gauge but why would my PFC be seeing both afm and map?
Seeing it and using it are two different things. It may be used for boost control but not for fuel and ignition.
The factory R34 ECU uses AFM for steady-state and MAP for transient throttle.
The nicer it drives on partial throttle is from the extra power and trims the later ecus have. Point being, dollar for dollar if you can do everything yourself the long block option shits all over a going to a haltech from a pfc, way more off boost torque and power and pretty much 1000rpm less boost threshold.
So many variables, like mentioned and in addition
the willingness of one tuner to push it harder
and another being more conservative.
If he used the same tuner and dyno something had to be wrong with it
mechanically or electronically.
Its common for people to go from a factory ECU to a pfc and gain 15kw minimum, are you suggesting that going from a factory ECU to a haltech with no other changes nets 35kw? Ludicrous
Full power is dictated by the engine spec, condition and state of tune. In this day and age and even for the past 10 years 99% of aftermarket ECU's will run engines to their full power potential.
I do actually know what the difference is, while I haven't used a haltech, I have gone from stock ecu, to power fc, back to stock but flashed. Granted it wasn't on a GTR but the results are still indicative. and FYI there wasn't a lot of difference between the M800 and flashed stock ecu in terms of drivability.
Don't get me wrong, a better ECU is nice, but for a lot of people there are not the number 1 priority if they already have a PFC
That would be like having a garrett GT series turbo, then upgrading to an EFR because they can spool a little earlier.
Not the best analogy, ok it would be like going from a strong single plate which is rated to hold more tq then what you have and upgrading to a nismo twin plate because it drives nicer and can hold a bit more tq. But at a cost of 3x of what you currently have, which is holding up fine.
  • Like 1
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
