Hey guys, i recently picked up a c34 Stagea series 2 RS Four S Dayz edition . I got this completely stock a few weeks ago.
10849839_766900880056693_709592562314056
10801794_766900933390021_369692916991287
10418917_766900960056685_981780862303257
10849930_766901010056680_925095451968798
1526396_766901036723344_7135578613636870
10805767_766901053390009_531910469256076
10847896_766901086723339_424902828485210
1517533_766901116723336_2923269923810884
the mods have started . first mod was to fit the R34 GTR front end , I've always loved Stagea's but never liked the fronts on C34, that was quickly fixed by the front swap, comprising of :
genuine R34 GTR bonnet, front bar and headlights, Modified R34 GTR reo, and Masa motorsports conversion guards :
10850304_766901153389999_910459790115006
10849765_766901186723329_563542543602668
10357181_766901216723326_239661420468691
10424325_766901240056657_401040530307880
11361_766901256723322_282134691654411782
10645087_766901280056653_128553219466225
13826_766901323389982_651233323238305608
1908211_766901353389979_1188113951399964
10846024_766901373389977_533752640753253
10644847_766901403389974_882877404639221
10367591_766900936723354_666542419395360
front finished, sorry for the iphone potato pics :
10391056_761252593954855_578911880337145
10336640_761252693954845_118500943871505
the front was dontated from a C34 front cut that had already had the swap in Japan. The same car also donated its Fujitsubo cat back, Greddy front mounted intercooler and Apexi pod ( as the HKS Death filter was crumbling) . Ive also fitted BC coilovers and the 2005 G35 Coupe 19's .
soon to come are Autech RS260 side skirts , rear bar and rear wing, then a full respray over christmas.
Ill update as this as the build continues. thanks, Ben .
Edited by mechanicalstig
  • Like 10
https://www.sau.com.au/forums/topic/451482-mechanical-stigs-c34-stagea/
hey guys, its getting a color change , not entirely sure on final hue yet but it wont be a radical change.
future plans are pretty open really but above all needs to be a practical daily so will get more cosmetic mods than performance.
few things o nthe cards are a haltech platinum plug and play and flex tune and put the 3 inch dump on. apart from that nothing is really locked in .
Thanks,
Ben.
  • Like 2
Yeasss going all out with the haltech, is scotty going to set all that up for you? I'd love to do exactly that in my 34 but to much $$$$!!!
Please don't paint it like Midnight purple, or bayside blue... do a colour that every other import owner hasn't done yet!
Heh, I love the colourful graffiti language on the burnt down building.
Looks the goods! R34 front end is best, the rays wheels in white looks great.
Edited by M35woah
  • Like 1
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
