Itd be too much stuffing around trying to get AWD from a VQ35, you would just stick to the VQ25. Which is oh so original and exciting.
You know they made an awd vq35 stagea, yeah?
Love your work, seen many similar conversion start but never finish... but you seem to be smashing through all obstacles with great precision!
Down the track I hope you drop in the 4.5L crank and tickle the bores :)
Absolutely loved the series mate. I've been thinking for ages that a turbo V8 would be perfect in the Stagea. Good on ya for sticking with the manual box. It's gotta be a lot of fun. I must say the amount of detail in the series really drives home how much effort is required to do an engine swap like this. Bloody heaps! Damn awesome work. The workmanship looks second to none.
Why a VQ35 is the real question.
The VQ35 is an underrated engine. People didnt take to it for tuning the same way they did with an RB engine despite the fact that it actually lends itself to forced induction well. People using the HKS twin turbo kits are pushing around 400-450 rwhp on only 7psi of boost . The V series skyline was also used to test engine/drivetrain configurations during R&D for the R35 GTR. Ben did also say he wanted a nissan derived engine too, but that V8 was a good choice too
  • 7 months later...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
