yo
I was driving my mates r34 gtt today it has 330 kw blah blah, with a heavy duty clutch and standard drive train.
As i hit boost in second gear it broke the passenger side rear drive shaft. This is the second time its happen on the same side. The drive shaft has lasted two months tops since its been rebuilt.
as any one else had this problem ? does he maybe have a problem with his diff causing it to break on the same side ?
thanks in advance ?
https://www.sau.com.au/forums/topic/451743-breaking-rear-drive-sharfts/
Just because it snapped coming on boost doesn't mean that's what killed it, the damage was done (not long) before the failure looking at the pics.
How hard does he drive it? Would take a massive shock loading to snap that shaft...
  • Like 1
No, GTR are outright 6 bolt, plus stronger everything.
NA should be 2x3 6 bolters, like S chassis cars, with the weakest CVs. R32/3/4 turbos should be 5 bolt with the "medium" strength CVs.
I must be going crazy, Could have sworn when I was looking at driveshafts when I snapped mine the GTR ones were 3x2 but a quick search now it seems that they are 6x1. Going senile at age 25 it seems..... :S haha
When I snapped mine I figured it was from excessive axle tramp (the initial fracture) and a hard launch one day finished it off. It was a very similar failure to yours. This was on 195rwkw with 19" wheels and 265 wide rear tyres. I now have near 300rwkw and 18" wheels with 265 tyres and Havent had a driveshaft problem since the first one. Mind you I dont go dropping my clutch and doing skids
Any pot holes or rough road when it happened?
Saw a gearbox break recently due to this, going onto power, car got slightly light and back down again over the roughness killing the box.
Never had a issue on the flat in the past.
As could axel tramp.
  • 1 month later...
  • 3 years later...
On 12/15/2014 at 5:55 PM, r34unit said:
post-99078-14186264603518_thumb.jpgpost-99078-14186264727933_thumb.jpgypost-99078-1418626504493_thumb.jpgpost-99078-14186265196841_thumb.jpg
Nice pics, very interesting break. I'm no expert but it looks like metal fatigue.
https://en.wikipedia.org/wiki/Fatigue_(material)#/media/File:Tender_fatigued_axle.JPG
If the replaced driveshaft was a used part a contributing factor could be that the unit was repeatedly loaded beyond its intended limit during its lifetime aswell. Similar to when you bend a paper clip at the same point until it eventually snaps.
Dark, corroded void near surface looks like it may also be a manufacturing defect but that's just assumption, could be just oil stain.
As to why coincidently passenger drive shaft failure may be to do with how the differential is transferring load, similar to how an open differential spins one tyre under certain conditions.
May only be far fetched and theoretical but hope this contributes to the discussion.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
