I plan on testing the balance of the balancer however with the same amount of material being removed on all sides it should not too be much out of the original balance.
I would be interested in the results from this, modifying the factory balancer could save $700+
I have the ross 32-2 teeth setup with the standard CAS for phasing
There are plenty of kits floating around the world ATM, but it is always good to see someone else's approach to this issue
You just use the input that would normally read the crank angle output from the factory CAS, it just has to be programable
Are you saying the factory cas can be retained and the signal just has to be modified so it can be interpreted?
I'm not sold on the design of the cam trigger finger, but everything else looks great
Edited by BlackBox
I'll let you know once i've found someone to balance it for me.
The factory CAS could be used in theory just as a reference. The factory CAS disk has 360 outer slots and from memory a single inner ring for the reference.
Me either at this stage. I'm happy with just using a steel bolt on the adjustable CAM gear however I thought people would like something universal without the need for a aftermarket cam gear however I guess in the scheme of things having to spend $300 on a pair of gears isn't a bit deal.
Nah I didn't have to touch the stock Cas just pick up the crank signal at the ECU plug and run a new wire to the crank trigger then change the settings in the cam/phase settings to read the 6 different sized slots in the ECU, it has an event counter it phases from
The new design cam wheel looks heaps better
  • Like 1
Thats what always had me wondering why people were putting a new sensor on the cam, factory one already has it for cam position phasing, just dont use the signal from the 360 outer slots and run a wire like you did from the crank trigger.
Makes life so much simpler.
If somebody could describe how to do this in a bit more detail I would be extremely appreciative, (pm if necessary don't want to deviate too much more)
The FC can't do this, I would be a little suprised if even the top Haltech could do it, interested to know if it can for sure
Easiest way with the FC is get a 36-2 trigger wheel with the missing teeth @ 85deg after TDC and the convertor box from Ross to convert the trigger wheel signal to what the FC will read, can also be used with stock and Nistune ECUs
That makes no sense
The ECU only works as well as the hard wear giving it reference
I understand that but I have read many posts sayin that it's a problem only with the newer ECU, because of the optical sensor and the speed of the new ecu's..
The concencus of the recent discussion (in another thread not far from here) was that older, slower ECUs are not seeeing (all) the timing fluctuations that the newer faster ones are. There may be some placebo involved iin that findiing, because the comparisons may not be sufficiently scientific (ie, same car, same timing belt, same CAS, just the ECU changed). But it is distinctly possible that it is true.
  • Like 1
    • Nice one, I'd argue that the white S1 RS260 is certainly the best looking of the Stageas. And yes, fully agree on the forum situation. It's a bit of a shame, but at least SAU is a good place to be. I found the facebook groups to give me FOMO because people were trying to one-up each other and show off in some way. Feels much more natural here. There are people with seriously nice builds, but I can appreciate it rather than it making me question my life choices. Might be that people are more open with sharing how much work/money/suffering it takes to actually get there.
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
    • Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"? (I know you need them for legality in NSW)
    • 1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out I'll Dremel out and form the angle and mounting point on the lower section when time permits  As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
