I plan on testing the balance of the balancer however with the same amount of material being removed on all sides it should not too be much out of the original balance.
I would be interested in the results from this, modifying the factory balancer could save $700+
I have the ross 32-2 teeth setup with the standard CAS for phasing
There are plenty of kits floating around the world ATM, but it is always good to see someone else's approach to this issue
You just use the input that would normally read the crank angle output from the factory CAS, it just has to be programable
Are you saying the factory cas can be retained and the signal just has to be modified so it can be interpreted?
I'm not sold on the design of the cam trigger finger, but everything else looks great
Edited by BlackBox
I'll let you know once i've found someone to balance it for me.
The factory CAS could be used in theory just as a reference. The factory CAS disk has 360 outer slots and from memory a single inner ring for the reference.
Me either at this stage. I'm happy with just using a steel bolt on the adjustable CAM gear however I thought people would like something universal without the need for a aftermarket cam gear however I guess in the scheme of things having to spend $300 on a pair of gears isn't a bit deal.
Nah I didn't have to touch the stock Cas just pick up the crank signal at the ECU plug and run a new wire to the crank trigger then change the settings in the cam/phase settings to read the 6 different sized slots in the ECU, it has an event counter it phases from
The new design cam wheel looks heaps better
  • Like 1
Thats what always had me wondering why people were putting a new sensor on the cam, factory one already has it for cam position phasing, just dont use the signal from the 360 outer slots and run a wire like you did from the crank trigger.
Makes life so much simpler.
If somebody could describe how to do this in a bit more detail I would be extremely appreciative, (pm if necessary don't want to deviate too much more)
The FC can't do this, I would be a little suprised if even the top Haltech could do it, interested to know if it can for sure
Easiest way with the FC is get a 36-2 trigger wheel with the missing teeth @ 85deg after TDC and the convertor box from Ross to convert the trigger wheel signal to what the FC will read, can also be used with stock and Nistune ECUs
That makes no sense
The ECU only works as well as the hard wear giving it reference
I understand that but I have read many posts sayin that it's a problem only with the newer ECU, because of the optical sensor and the speed of the new ecu's..
The concencus of the recent discussion (in another thread not far from here) was that older, slower ECUs are not seeeing (all) the timing fluctuations that the newer faster ones are. There may be some placebo involved iin that findiing, because the comparisons may not be sufficiently scientific (ie, same car, same timing belt, same CAS, just the ECU changed). But it is distinctly possible that it is true.
  • Like 1
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
