Batch 1 has been ordered and paid for with the Factory and product time is 25 days so now the wait starts.
Thank you for all the local guys who commited and the fellows from Canada and the USA - You got a bargain with the Exchange rate! Should of charged you double.
Oh well not in it to make money:)
Ok well the car is back from a fresh coat of paint and looking smick!
Well now back to the project, All fitted up ready for the harness to be matched up from the OEM CAS wiring.
post-23119-0-30786700-1430626968_thumb.jpg post-23119-0-88659300-1430626970_thumb.jpg
post-23119-0-37346800-1430626973_thumb.jpg post-23119-0-53413900-1430626975_thumb.jpg
News from the Factory puts the first batch about 2 and a bit weeks away...
  • Like 3
Car looks awesome so do the parts!
They are still due to be shipped on the 25th From the Factory as planned. I spoke to the Factory Saturday evening and production has started and they will be out for finishing around Wednesday.
Guys,
I have two sets coming without being spoken for. IF your interested let me know and I'll put you on the list.
Final lot of parts off to be finished in Black.
Dads Birthday pressie also made just for a bit of fun for a small steam engine
Edited by murrayis
Hey Guys,
Slight Delay in shipment due to there being a flaw in the finish of one of the items. I've chosen to have it refinished rather than shipping a defective product. I hope you can understand.
The factory has said they will have the parts back tonight and will provide pictures on the finished products before shipping tomorrow
Thanks for your understanding.
Guys
Shipping has been arranged and awaiting confirmation of pickup. Tracking numbers will be dispatched in 2-3 days once they reach the Forwarder.
Everyone will get an email with these details asap.
Cheers
Cameron
Edited by murrayis
Morning all,
Batch 1 is now official and has arrived! I've just unpacked the Aussie stock to ship out later today and I could not be happier with the result.
I hope everyone is happy with their product once it arrives!
post-23119-0-55144800-1433122139_thumb.jpg post-23119-0-10481200-1433122142_thumb.jpg post-23119-0-06661100-1433122145_thumb.jpg
post-23119-0-48867900-1433122146_thumb.jpg post-23119-0-91522300-1433122147_thumb.jpg post-23119-0-39728500-1433122149_thumb.jpg
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
