Mine arrived and look perfect! VERY VERY impressed with the kit! This is a no-brainer compared to the other options out there and is extremely professional. Don't worry pictures are coming as soon as I get the head on my engine.
My car is at the tuner right now facing this timing jitter problem. Two different CAS tried so far and no change, a third one being tried next week. I'm not holding my breath.
Has this kit been installed and tested on a car yet? Like up and running, tuned and everything. It would be good to see some before and after log graphs. They would also be beneficial as future sales material.
G'day mate - sorry for the delayed reply.
The kit is designed as a DIY solution where some adjustments may be required to suite your setup. But given that I have it running on my Car however a old Haltech e11v2 without any issues.
It is based on the specs of the GT101 sensors require for spacing etc so I do not expect any issues with their design long term.
Signal will be similar to other kits.
Cheers
Cameron
    • Hot tip, stop picking at shit. Live in bliss instead   From my recent experience in rust repairs, white it may seem to not go much further back, you'll still need to cut back a bit further.  From what I can see there, the outer skin, and the inner is rusted too. From what I can see you've got the inner one which is all structural, and window likely affixes too.   If tag Murray Calavera here, but my phone won't let me tag him, he'd probably be able to give the best advise.   I do know, welding roof panels is a right pain in the bollocks! Very heavy to heat distort the roof and warp it all.
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
