OK helpful advice coming down the pipe.
About the Cam wheel and trigger:
1) The flat head cap screws that the trigger is apparently designed for are near impossible to find. I will be making some myself by machining normal M7 cap screws. The cams have M7x1.00 pitch threads...yes M7x1.00. Should have known when I had to get the 11mm socket out that something was funny. With my Tomei cam gears (and Tomei cams) I needed 43mm of depth for a NORMAL headed bolt to go on. a flat head screws should be similar length...Flat head cap screws are a great idea though because the countersinking will allow more room under the top timing cover (I'll get to that in #3 below). I have attached a picture showing NORMAL BOLTS M7x1.00 (50mm cut down to 43mm length). I also am using the factory plate and added lock washers.
2) Be Prepared to cut your timing cover. Thank goodness I had this gaudy Nitto clear cover and it trimmed out very easily. The sensor still SLIGHTLY protrudes into the flat plane of the cover, but I bet I could lightly file it (1/8" or so). I will be making a new plate to rivet on to my Nitto cover in the shape of the (sorry to say) Alien-head-shaped hole. Again see pictures for clarification. Not much about the design could be changed to rectify this.
3) The bolts from #1 above will definitely break the plane unless I find some flat head (countersunk) M7x1.00 cap screws. I'm telling you they are impossible to find...I'll be making some.
Crank pulley trigger:
1) I have the Tomei oil pump and it's cast differently than the factory oil pump. The pressure adjusting part of the Tomei oil pump makes the installation of the lower trigger impossible. I will have to make another option. Also It looks like my Fluidampr harmonic balancer won't work either. I will be making another tooth and pickup arrangement for my setup, but I kinda suspected that before ordering (and now we know!). Also note in my pictures that the harmonic balancer is not pulled very far onto the crankshaft yet.
Overall very pleased. WE need to find a solution for the cap screws on the cams and I believe this should be included in future kits.
Thanks!!
The lower bracket and Tomei pump issue, no room to machine the bracket out to fit over the pump?
Or does the sensor itself still hit the added oil relief casting on the Tomei pumps regardless of what you do to the bracket its mounted on?
Murrayis,
No sweat. The effort was valiant. As I like to say, "The credit belongs to the gladiator in the arena...not the critic in the stands". You've done great aside from pick an odd ball cap screw that I'll need to probably have machined, but i figure thats more of Nissan's fault than yours. To be fair I figured I was on my own with the crank dampener regardless...now we know. Now we are both gladiators in the arena.
Send me the drawings, I am a mechanical engineer with the ability to get our problems solved and likely cap screws made! What is the bevel angle and diameter?
really impressed. great work. really like the crank trigger setup, as for teh oil pump fitment clearence issues, perhaps thats why other setups are mounted from say the oil pan rail, rathern than the front of the block.
I would be real keen to find out if its possible to create a disk setup that works inside of the stock CAS, essentially keeping it looking stock at the front.
would hate to CUT up a nice set of 26 painted covers.
Great to hear Robert.
Guys and Gals - I am going to do 1 more run with the factory and leave this project as Open Source.
If you want in please let me know as the order has been placed with the factory and they are waiting on confirmation of numbers - With the USD v AUD not looking to improve any time soon the cost is slowly increasing to produce.
Currently there's 15 sets out in the world from Canada to Tasmania all the way to Sweden - I could not be more happy with how this project has turned out.
Cheers
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
