hi there i have a 1977 c210 that is running rough at the moment do they have general problems with there carberators , i have changed the coil / spark plugs / tested leads & next thing i am thinking of doing is overalling the carbie .
spoke to a previous nissan mechanic from tha seventies & he did nothing but bag the l24 motor saying that they where renound for wearing out cams due to poor lubrication system & said they where nothing but a hassel to work on.
i left his workshop thinking surely they are not that bad . i am a previous v8 ford / holden man & know little about early model skylines . any reply would be great cheers my77sky
the are awesome compared to what holden had at the time
remember the L6 engine was first used in 1969
so it is an old design and in front of tech than even todays LS V8 engines, OHC anyone?
the mechanic who bagged the L24 probably another holden or ford fanatic,
the l24 is pretty much an indestructable motor, reliable and simple..i never know problems regarding lubrication, or that wearing out
cams?? was he kidding. i have owned skylines which have done in excess of 500.000kms the cam was never
replaced..maybe this mechanic was approching the dementic age,
if you need to compare the holden vb commodore or the xc ford of that time compare to a c210 skyline
the quality is such that the holden or ford belong in noah;s arch..along with that stupid mechanic..
cheers to all skyline owners
  • 1 month later...
dear bro'S
i am newbie from malaysia...nice to know c210/c211 owners
just buy c210@180k sedan,car is slightly rusty ..send the car for bodywork and painting
i have question here
i want to take out my original axle and put drive shaft rear end,can i plug n play 180sx or rps13 rear end?
another thing is adjustable suspension...my frenz say can put 180sx or cefiro a31,just need little modification..is it true?
thanks for the help
Edited by boxer_power
  • 3 weeks later...
Wrong Thread dude!
Try www.r31skylineclub.com
:thumbsup:
How is it the wrong thread? He has a C210, and clearly posted that he bought a front cut to transplant into said C210.
Welcome boxer_power!
yes 180 sx struts will fit with some minor mods, the front will require a bit more work than the rear, use the search function, there is plenty of information on the subject.
Cheers
Jason
  • 4 weeks later...
hi there my 1977 datsun / skyline is running like a clock now , a mate pulled the carbie off & it had some crap in it . looking forward to catching up with everybody at the all japan day at silverwater .
cheers my 77 sky
  • 3 weeks later...
  • 5 months later...
any
R30 diff is an R180(So is the C210's) but they are tuff as anyways...only reason to put an R200 would be for the lsd that is harder to get for R180's and for that lil extra strength if you are doing a LOT of clutch dumping with big rubber.....
Rear struts are straight bolt up....tailshaft is bolt up.the only thing MAY be the width of the rear subframe....but that shouldn't be a problem either.....
I have a complete rear clip for the r30 sitting in my shed ready for my C210 coupe.....havent measured it but cant see a problem( hang on,, im not tim.....I'll shut up now)
anyone can help me out with me pc210 skyline 180k?
my car comes with a rear dead axle and thinking to swap with a r30 r200 diff with lsd
when i got the complete rear end and i found out that width is slightly wider
any idea can recommend for me?fabricate a bracket to mount with it etc??
saw the first page looks like got few people managed to mount it lol
hope to get your help asap...
thx in advance
i recently put an R30 rear end in my c210. was a straight swap. the only difference i found was the handbrake cable between the discs is shorter with the r30 rear and the c210 one doesnt go back far enough to meet it.
I don't think you can install a IRS diff into a PC210, being live axle i would assume there'd be no crossmember or mounts for a crossmember for it.
Can you take pictures for us?
ok will take the photo when i am free
but i thought the chassis and undercarriage of pc210 design would be almost the same with sedan c210 (any version)
sad....no enough study before start modifying......
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
